IS THIS TRUE?
Old Sep 6, 2004 | 06:49 PM
H...ADDICT's Avatar
Default IS THIS TRUE?
I remember back in the day that Gary Kubo used to build 1.9 liters out of B16 block, using B17 crank and rods, is this true?
Old Sep 6, 2004 | 08:25 PM
rjay8604's Avatar
Default Re: IS THIS TRUE? (H...ADDICT)
i think you would need 86mm bore and it would be a little under 1.9, anywho not sure if its true.
Old Sep 6, 2004 | 10:53 PM
rjay8604's Avatar
Default Re: IS THIS TRUE? (omniman)
can't argue with omniman
Old Sep 7, 2004 | 03:52 AM
H...ADDICT's Avatar
So thats what i thought, here is another question, Im gonna use a B17 head with June 3s, what would be the highest compression pistons I can use without the valves hitting the pistons on the dyno, when they retard/advance the timing on Jun 3s, Thanks a lot guys.
Old Sep 7, 2004 | 04:33 PM
H...ADDICT's Avatar
to the tizzup.
Old Sep 7, 2004 | 08:06 PM
dfoxengr's Avatar
i doubt anyone could actually answer that seeing as how a few things make up compression and volumes, try something and clay it. if its too small compression the mill the head or thin up the h gasket.
Old Sep 8, 2004 | 05:19 AM
H...ADDICT's Avatar
THANKS MAN, I GUESS ILL JUST HAVE TO START WITH CTR AND CLAY IT.
monster_c
Apr 5, 2012 09:53 AM
Eg6DR
Mar 6, 2008 07:27 AM
Full Race A6
Sep 22, 2004 09:34 AM
Slava.
Apr 13, 2004 11:13 AM
Can'tCatchMe
Apr 13, 2004 10:14 AM
