What sway bar will fit with Neuspeed rear tie bar?
I know the suspension techniques bar will NOT fit with a Neuspeed rear lower tie bar in place. So which sway bar WILL fit with the bar? Thanks in advance!
hmm i have a neuspeed reaer lower tie bar. and a suspension techniques rear swaybar i'm putting ont his weekend. dont think i'll have any problems getting both to work.
i got a skunk2 sway bar and neuspeed rear lower tie bar. fits fine. i cant imagine any sway bar not fitting with it though. the mounting points for the rear sway bar are above the ones for the tie bar so its pretty hard for them to hit.
The only reason the Neuspeed bar won't fit with the ST sway bars is b/c the bolt that comes with the Neuspeed bar isn't long enough. Just go to your local hardware store and get the same size bolt w/same size thread, only like an inch longer, and viola! It should fit.
revvin9k
Aug 5, 2004 09:14 AM
moridin2004
Jan 10, 2003 01:44 PM
Zer0DazE
Jul 25, 2002 05:04 AM
