odb0 b16a ecu wire guide?
I'm looking for where I'm supposed to hook up the oil pressure wire and the vtec switch wire to the ecu. I have not hookup up these things with an obd0 ecu before.
Any links or info would be greatly appreciated
would the vtec pressure switch be one of the two wires comming our from the green connector below the solenoid? Where would the knock sensor wire be? and the 2nd o2 sensor? do i need to hook those up for vtec to kick with the stock ECU?
From: I told you to wait in the truck in Texas, United States
Go here: http://b16a.honda-perf.org/theswap.html
Click on the words "oil pressure switch, VTEC solenoid, knock sensor, and the second O2 sensor" etc. and it will show a pic of it...
Here are some good B-16 links:
http://www.geocities.com/dropp...p.htm
http://www.phatwhippincrx.20m.com/custom.html
http://tjshondas.20m.com/b16ainstall.html
http://www.customcivics.com/~brandon/
http://www32.brinkster.com/tjshondas/default.htm
There is also some good info at http://www.hasport.com
DeKaP
14
Sep 12, 2004 06:51 PM
