Clutch Cable on LS in HF
Ok, we have the LS and HF clutch cables, the HF clutch cable is longer by about an inch or so, but both of them are still too short to get on the pedal and the clutch lever. There is a staged clutch in the tranny so we can't pull up on the lever to get it out. WE can get the clutch on the lever but when we hook it to the pedal the little clip barely is poking through the firewall and definately not long enough to go over the top of the pedal. Any suggestions guys? Sorry I am new at this cable clutch stuff, all i I have ever had was 92-95 civics and my 01 Integra.
you gotta figure out a way to get the lever up higher..... you could also hook up the end......then take off the top bracket move the cable over it and reattach it.... it should work
Well this is what we tried last night, don't laugh, but it still didn't work, we jacked up the car, put a jackstand under the lever and slowly lowered the car, well the car rested on the jacstand completely which was on the lever and it was still not high enough to put the cable on.....
