weird starting problem
Old Sep 6, 2004 | 10:27 AM
crxgator's Avatar
Default weird starting problem
for a couple of days nows, i would go to start my car, it runs for a sec, then dies...but then the 2nd time i start it, it will start up and stay running...
no CEL's, anyone have any ideas what this could be?
Old Sep 6, 2004 | 11:21 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: weird starting problem (crxgator)
If you have a fuel pressure gauge, have a friend start the engine and look at the gauge to make sure the pressure is not dropping.
If it is, it could be the main relay sticking.
Old Sep 6, 2004 | 12:41 PM
Jared's Avatar
could be the main relay sticking, could be a fuel pump or fpr leaking fuel pressure down, could be a dying coil or ignitor
Old Sep 6, 2004 | 12:45 PM
nigel39's Avatar
every since I purchased my rex sometimes after filling up w/ gas it wouldn't start right away, it got worse in the summer till the point that anytime I tried to start my car it may or may not start. the hotter it was the worse it was. Rarely had problems at night. I replaced the main engine relay and I have had NO problems w/ any starting since then. That relay effects alot of stuff. roughly $70. at dealer.
Old Sep 6, 2004 | 12:46 PM
Jared's Avatar
Default Re: weird starting problem (nigel39)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nigel39 &raquo;</TD></TR><TR><TD CLASS="quote">every since I purchased my rex sometimes after filling up w/ gas it wouldn't start right away, it got worse in the summer till the point that anytime I tried to start my car it may or may not start. the hotter it was the worse it was. Rarely had problems at night. I replaced the main engine relay and I have had NO problems w/ any starting since then. That relay effects alot of stuff. roughly $70. at dealer.
main relay powers up the fuel injectors and the fuel pump, both essential to starting.
Old Sep 6, 2004 | 01:37 PM
crxgator's Avatar
Default Re: weird starting problem (Jared)
im going to replace the fuel filter and then try my extra main relay...
Old Sep 10, 2004 | 04:09 PM
crxgator's Avatar
ok its not mechanical, its something electrical...when this weird situation happens, if i were to put my key in the on postion, nothing in my car would light up, not the clock, radio or any dash lights...but if i were to turn it off and on and take the key out and try it again the lights would come back on...wtf...
n00b question, semi-blown ignition fuse?
Old Oct 28, 2004 | 04:07 PM
crxgator's Avatar
ok, wow i should have updated this, but the fix was a new ignition switch...mine was all burnt on the big white wire...
installation takes like 15 mins, and very easy to do...
White98LS
Jul 14, 2007 07:46 AM
H22Ej1
Jun 14, 2007 09:30 PM
jury
Jan 1, 2007 10:57 AM
92TEGsrSC
May 18, 2006 07:34 AM
SpoolinEK9
Mar 15, 2005 04:25 PM
