Honda Civic LX 1998
Old Sep 6, 2004 | 08:51 AM
mickyhunt's Avatar
Default Honda Civic LX 1998
stopped fpr gas - turned off engine - then when I tried to start, the engine would not turn over - everything sounds like it should but the engine doesn't kick in - removed wore from cap - no spark from cap to wire. Hoping it is the coil. Can the tming belt effect the spark in any way if it broke? Took cap off - everything is clean - no burn marks.
Thanks for your help
Old Sep 6, 2004 | 09:31 AM
Kendall's Avatar
Make sure that everything is cool with the starter. It's possible that a wire is loose, beyond that, there are any number of other possibilities. Sounds like you need to invest in a good multimeter.
Old Sep 6, 2004 | 01:22 PM
mickyhunt's Avatar
Default Re: (Kendall)
I think the starter is ok - sounds like it is trying to turn over - just not getting spark to the plugs
milostack
Jan 22, 2018 03:06 AM
rarolfe
Oct 4, 2013 09:44 AM
Shake'nBakeCrew
May 14, 2010 02:52 PM
britanns
Dec 12, 2007 05:17 PM
turbo gsr
May 12, 2007 12:06 PM
