Stock GSR V's Skunk2 inlet manifold
I've just dropped a B18c1 into my EG hatch after by B16 blew
So far I've done the following:
EK9 Cams, springs and retainers
Cam Gears
DC 4-1 JDM Style Stainless Header
2.25" ID exhaust and test pipe
HKS super Power Flow Intake
B&M FPR
V-AFC II
Would I see gains or losses from swapping the stock GSR intake mani for a Skunk2 one, I also have a 64mm TB to put on at some point.
Cheers Guys
So far I've done the following:EK9 Cams, springs and retainers
Cam Gears
B&M FPR
V-AFC II
Cheers Guys
So is it a worth wile mod rather than swapping to a P72 GSR ECU and installing a knock sensor as my engine doesn't have one?
Certainly sounds easier if you ask me
Might help out a bit. I was in the say place, didn't know weather to a skunk2 intake manifold or just bore out the stock. I also had a 64 mm throttle body. What I did was bore out the stock my self. I'm in the process of fin up it take's a while but I think it's wroth it for me. I didn't what to elimnate the butterfies. It depends on what you want to do?
https://honda-tech.com/zerothread?id=974809
JDMvtecDRAGSTA
Mar 29, 2004 09:00 AM
