CRX Manual!!!!
Hi there,
I have just brough a crx and was wondering if anyone knows anywhere i can down load the users handbook as its a jap import the book is in japanese!
Quick tips would be appreciated r.e:
1. What does the button that says pole on it do?
2. Whats the difference between d3 and d4 on the auto gear box (is one faster etc..)
3. what should the mpg be of an un moded vtec on 92 del sol 1600cc? As it seems to be drinking petrol, think there may be a problem as it constantly has at least 1000 on the rev counter! Was told it would do about 27/gallon
Many thanks
Ian
Many thanks
Ian
that one is ok, but if u want to save it, use this one... i made the mistake of saving all the stuff that was there by myself & took me about 2-3 hours... if u use this one, u will most definatly save time
http://www.crxpower.net/~silve...l.pdf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reds »</TD></TR><TR><TD CLASS="quote">1. What does the button that says pole on it do?</TD></TR></TABLE>
Raises the marker pole on the side of the front bumper to help with parallel parking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">2. Whats the difference between d3 and d4 on the auto gear box (is one faster etc..)</TD></TR></TABLE>
D3 only allows the transmission to use 3 gears; it will not allow the transmission to shift into 4th. D4 allows it to use all gears, including the overdrive 4th gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">3. what should the mpg be of an un moded vtec on 92 del sol 1600cc? As it seems to be drinking petrol, think there may be a problem as it constantly has at least 1000 on the rev counter! Was told it would do about 27/gallon</TD></TR></TABLE>
Should be between 25-35 mpg, depending on how you drive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red91CRXsi »</TD></TR><TR><TD CLASS="quote">try this:
http://www.honda.co.uk/owner/CRXManual/
He has a del Sol, not an '88-91 CRX.
Thanks guys - found the pole! thats teh reason ther is a crack in my bumper it doesnt have a hole! Means its been pushing against teh bumper and has caused it to crack
One other thing - when i hit 80+ in it the tcs light comes on - what does this mean - also i have a tcs button but this doest seem to actually do anything - any ideas / info
Thanks
Reds
Thanks
Reds
CRX_RUS2
Mar 15, 2005 11:38 PM
crxforum
May 17, 2003 08:02 AM
