hf, si injectors. what's the diff?
Old Sep 6, 2004 | 01:31 AM
junkyardRx's Avatar
Default hf, si injectors. what's the diff?
i understand that the injectors on the hf and si are different. to the japanese speaking people, i've read the following on the injectors.
hf says "shichike"
si says "suraho"
anybody know what that translates to in english? it's both written in katakana and maybe this would also help in differentiating the two. also what's the flow rate on each? thanks.
by the way i changed my injectors cause the hf injectors i had was cracked causing a code1, if you're having a problem with the code 1 and changed the fpr and 02 sensor to no avail, you might wanna check your injectors. hope this might help somewhat.
Old Sep 6, 2004 | 04:02 AM
NCchris's Avatar
Default Re: hf, si injectors. what's the diff? (katsumoto)
Most all honda injectors are 240cc/min. Some of the prelude injectors are diff. When I did my LS swap, I bought a set of Si injectors to use on the B18b to run as non-obd. For whatever reason (clogged, shorted, or broke) they did not work. Took the injectors out of the HF motor and it started right up. Still running them a year and a half later. No codes.
HTH
chris
Damills
Mar 3, 2009 02:56 PM
driftam1
Apr 21, 2008 10:19 AM
sporkcrx
Oct 21, 2006 01:07 PM
shadycrx
11
Jan 2, 2006 07:03 PM
Sampsonite987
Mar 30, 2004 02:11 PM
