oil in #1,2,3 need help asap
Old Sep 6, 2004 | 12:56 AM
93lsd's Avatar
Default oil in #1,2,3 need help asap
i just put together my sleeved 85m gsr block with 12.5 comp pistons and semi ported head this week and go it running tues. and noticed a smell of oil when i would come to a stop friday i checked into the cyl, and noticed that 1,2,3 looked alittle wet inside well tonight i was driving it trying too put some breakin miles, then started too smoke real bad, real bad so i checked the plugs and 1,2,3, were all full of oil and 4 was perfect, so where should i start to figure out what is causing it..
Old Sep 6, 2004 | 09:29 AM
johnzm's Avatar
Default Re: oil in #1,2,3 need help asap (93lsd)
ring gap, head gasket, and valve seals
Old Sep 6, 2004 | 11:11 AM
93lsd's Avatar
Default Re: oil in #1,2,3 need help asap (johnzm)
did a leak down test and a comp test and all cyl had barely 20% leakdown and did a comp all cyl, had 225 in each cyl but #3 had the most oil in it and that one was at 275psi i am thinking it is the valves seal, i bought the cheaper on nok compared too the high dollor ones that were like 5 bucks each we will just see till i pull off the head
EG6_LS_BOOST
Mar 18, 2014 05:49 AM
mr2passat801
Aug 15, 2010 08:16 AM
So Cal So Boosted
Aug 5, 2004 11:41 AM
bundy
Nov 19, 2002 09:04 PM
Chubz
Jun 10, 2002 12:39 PM
