Big Bore people. are you running spot faced comb. chambers???
Old Sep 5, 2004 | 11:16 PM
rjay8604's Avatar
Default Big Bore people. are you running spot faced comb. chambers???
I'm not quite sure if people that are running big bores are doing this and what their reasoning is. Are you people running stock size combustion chambers or are you opening them to the bore. My thought is there will be clearance issues with high compression and and big bore.
Old Sep 5, 2004 | 11:33 PM
b19coupe's Avatar
Default Re: Big Bore people. are you running spot faced comb. chambers??? (rjay8604)
85mm IB Wiseco Super Dupers and no clearance issues. 86mm IB Wiseco Ultimates and the combustion chambers were opened slightly at the ends, just to be safe.
Old Sep 5, 2004 | 11:50 PM
rjay8604's Avatar
Default Re: Big Bore people. are you running spot faced comb. chambers??? (b19coupe)
Are you running a pr3 or gsr head?
Old Sep 6, 2004 | 07:08 AM
b19coupe's Avatar
PR3 with welded combustion chambers-looks pretty much like GSR combustion chambers.
Old Sep 6, 2004 | 07:19 AM
asubennett's Avatar
85mm bore, chambers opened up to 85mm. JE 12.0:1 piston and PR-3 head. I wish i would not have done it. I want my missing compresion back. On the flip side though, this motor is very strong and I have zero complaints other than a little bit of missing static compression.
Old Sep 6, 2004 | 08:00 AM
respectblades's Avatar
Default Re: Big Bore people. are you running spot faced comb. chambers??? (asubennett)
do most setups that use a 84.5 bore or greater have to open up the chamber to match the bore size?
i'm a little confused on this concept because i hear about crvtec getting put together without having done much of any machine work
even in honda tuning when they did the 13 sec integra articles they didnt do any machine work to the head
what are the pro's and con's to a setup of that sort
Old Sep 6, 2004 | 08:13 AM
1 2 NV's Avatar
Default Re: Big Bore people. are you running spot faced comb. chambers??? (respectblades)
84.5mm bore 13.4:1 CR and we didnt open up the combustion chambers.
Old Sep 6, 2004 | 07:54 PM
rjay8604's Avatar
Default Re: Big Bore people. are you running spot faced comb. chambers??? (1 2 NV)
yeah, i just don't want any detonation if the piston deck is like .010 inch from the head.
Old Sep 6, 2004 | 11:15 PM
JL's Avatar
JL
84.5 with opened chambers.. ~11.5:1, need more compression, bigger pistons!
CustomX113
Dec 10, 2006 02:31 PM
db2integra
Jun 27, 2004 08:02 AM
earl
Mar 21, 2003 09:09 PM
hondaless
Mar 3, 2003 01:11 PM
riceboy
Oct 19, 2002 08:19 AM
