ZC question
Alright, here's the deal......I want to swap a dohc zc into my si. i know it's basically a straight bolt in. My question is more about routine maintenance than anything else. What belts, oil filter, gaskets, etc. should I use? I see everyone on here asking about how to make it fast, but not what you should use to maintain the cars. Anyway, whatever anyone can tell me would be appreciated.
http://hometown.aol.com/nosajuf/nosajuf2.htm
Other Parts / Numbers can be used on ZC:
Timing Belt:-----1988 Prelude 2.0-----14400-PK2-004
Timing Belt Cover:
AC Compressor / Parts:-----1989-91 CRX/Civic-----N/A
AC Bracket:-----1988-91 CRX/Civic-----N/A
...The AC Compressor bracket bolts onto the ZC block.
Throttle Body:-----1988-91 CRX/Civic Si-----N/A
ECU:-----1989-91 CRX/Civic Si-----N/A
ECU:-----1986-89 Integra-----N/A
ECU:-----1989-1991 ZC-----N/A
Intake:-----1988-91 CRX/Civic-----N/A
Headers:-----1986-89 Integra-----Any Kind
Headers:-----1988-1991 CRX/Civic-----N/A
Plug Wires:-----1986-89 Integra-----Any Kind
Spark plugs:-----1986-89 Integra----- NGK BCPR6E-11
Distributor Cap:-----88-91 CRX/Civic-----N/A
Distributor Rotor:-----88-91 CRX/Civic-----N/A
Distributor Cap:-----1988 Integra-----30102-PM7-305
Distributor Rotor:-----1988 Integra-----30103-PM5-A05
Head Gasket:-----1988 Prelude-----12251-PM7-003
Intake Gasket:-----1988 Integra-----17105-PG6-S00
Exhaust Gasket:-----1988 Integra-----18110-PG6-003
Water Pump:-----1990 CRX-----19200-P01-004
Oil Filter:-----1988 Integra-----15400-PR3-004
Oil Filter:-----1988-89 Integra-----Fram PH3539A
Oil Pan Gasket:-----1988-91 CRX/Civic-----N/A
Oil Pan Gasket:-----1986-89 Integra-----N/A
ZC Pressure Plate:-----1989 Civic DX-----N/A
ZC Clutch Disk:-----1989 Civic DX-----22200-PM7-J02
Clutch:-----1990 CRX-----N/A
b) The integra valve cover from the same style / years does not fit. The Bolts are in different locations.
c) The black plastic timing cover does not fit. The two bolts are farther apart on the ZC cover.
Timing Belt Cover:
