converting to obd1..vss issue
i just thought about this which i can't figure out. i'm converting my crx to obd1 using p30 ecu. however, i just remember that vtec won't engage if vss is not working. now the ef's have mechanic gauge isntead of electrical. how would i be able to get this work?
Jeff-
Jeff-
The speedo cable runs from the tranny to the gauge cluster. The cluster converts the this into an electrical signal, and a wire runs from the gauge cluster to the ECU. You can convert to OBD-1 and keep the stock speedo, cable, and wiring. If you get a conversion harness, they repin it for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patch »</TD></TR><TR><TD CLASS="quote">The speedo cable runs from the tranny to the gauge cluster. The cluster converts the this into an electrical signal, and a wire runs from the gauge cluster to the ECU. You can convert to OBD-1 and keep the stock speedo, cable, and wiring. If you get a conversion harness, they repin it for you.</TD></TR></TABLE>
great..now you made it clear for me
always good to learn new things
thanks!
Jeff-
thanks!
Jeff-
hatchinprogress
12
Oct 13, 2009 11:40 PM
