4wheel disc swap
i just got a 91 hatch and i just picked up a second gen teg
i want to put the brakes on my civic has anybody done
the swap if so give me some tips
thanks this honda stuff is a lot more complex than nissans
but i like how much you can do to a honda
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX »</TD></TR><TR><TD CLASS="quote">Here's a how-to for the rears:
http://fourthgenhatch.com/reardiscswap.html</TD></TR></TABLE>
Beat me to it man!
Good luck, make sure you get some new rotors. Those calipers re built..and as usual new Master Cylinder and Brake booster. Since your swapping the lines, I suggest getting some Stainless Steel lines.
-Jon
Beat me to it man!
-Jon
To do front use the integra knucles. Use the civic uca's/lca's. Get a 10mm flare nut wrench. This also worked good for me, when disconnecting lines i put vacuum caps over the fittings. It kept air into lines minimal.
toEknEEg
90
Jul 16, 2008 12:42 PM
importimage
21
Jul 30, 2004 05:23 PM
Built Beast
Jan 23, 2004 10:58 AM
