B20 piston question.
Old Sep 5, 2004 | 02:59 PM
SiShane's Avatar
Default B20 piston question.
What pistons will yeild a nice 12.1 cpr on a B20vtec. Any suggestions or recommendations from past or current experiences.
Old Sep 5, 2004 | 05:36 PM
SMSP's Avatar
Default Re: B20 piston question. (CRexer101)
I have a set of new 85mm B20B pistons with rings and pins for $150. With some surfacing you won't get 12:1 but at least 11:1.
Old Sep 5, 2004 | 07:05 PM
b19coupe's Avatar
Try IB. Jeff has what you are looking for:
http://www.importbuilders.com/pistons.html
Other manufacturers offer pistons that will do the same job as well.
Old Sep 5, 2004 | 10:31 PM
Dancing is Forbidden's Avatar
Default Re: B20 piston question. (b19coupe)
HAHAHA! I know of some very cheap high compression pistons for a b20!!!! HAHAHA!
Old Sep 6, 2004 | 03:52 AM
Westrock2000's Avatar
Default Re: B20 piston question. (lsvt3c)
JE has off the shelf 12.5:1....I bought some from Summit about 2 years ago for $500.
its 12.5:1 with the B16 head...with a normal B20/B18B head, it will be around 12:1.
Old Sep 6, 2004 | 08:11 AM
PHiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvt3c &raquo;</TD></TR><TR><TD CLASS="quote">HAHAHA! I know of some very cheap high compression pistons for a b20!!!! HAHAHA!</TD></TR></TABLE>
-PHiZ
Old Apr 26, 2005 | 09:16 PM
HomeDepotMade's Avatar
Default Re: B20 piston question. (PHiZ)
would ITR oversize piston work for a b20? and what kind of piston can u use if your bore the b20 to a 2.1L?
Old Apr 28, 2005 | 12:42 AM
Vtec[Power]'s Avatar
I'm looking for B20b High Compression piston around 12:1?any 1 have?Pm me ur price!
Old Apr 28, 2005 | 02:40 AM
Cidone's Avatar
Default Re: (Vtec[Power])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hype Vtec &raquo;</TD></TR><TR><TD CLASS="quote">would ITR oversize piston work for a b20? and what kind of piston can u use if your bore the b20 to a 2.1L?</TD></TR></TABLE>
No because ITR pistons are only stock at 81mm so there over sized would only be .25 over that... B20 has a stock bore at 84mm with a 87mm crank... Thats how you get the 2.0lt
Old Apr 28, 2005 | 11:05 PM
wat piston recomend dor B20b!i need 12:1!compression!
Old Apr 29, 2005 | 05:54 PM
jdm92teg's Avatar
look for some je pistons. they're cheap but a good brand.
Old May 1, 2005 | 03:33 PM
B16Drag's Avatar
I have a set for sale. 84.5mm Arias High Compression pistons (12:1 with B16 head) and LS rods with ARP rod bolts. Perfect for B20-Vtec or Over bored LS block.
kenney
Nov 23, 2008 04:24 PM
g0tgot
Aug 25, 2007 12:54 PM
Power Rev Racing
May 11, 2005 05:35 PM
