1993 Honda Civic DX Question
Old Sep 5, 2004 | 01:28 PM
diego's Avatar
Default 1993 Honda Civic DX Question
I did a search and this seemed to be the most similar topic to my problem.
https://honda-tech.com/zerothread?id=979600
Before i try to go ahead with repairs I just wanted to make sure that my problem matched I hope that doesn't violate the issue about searching for a topic before you start a new thread.
A new distributor and cap were put in after a new valve cover gasket and plugs were also put in. APparently it was leaking into my plugs and causing the car to miss. When i came home a couple of days after the repairs (this morning) the clutch pedal stuck in the down position, I cant shift gears without the car cutting off, and the check engine light came on. It also shuddered and rumbled when i tried to start it for some reason. From what i've read on here I'm assuming the most likely cause is the above topic where it says my clutch cable snapped? That causes a car not to start or is that just responsible for me not being able to shift into gear?
Thanks in advance for any help.
1993 Honda Civic DX 1.5 L 5 manual transmission.
Old Sep 5, 2004 | 01:53 PM
JDMisGOOD's Avatar
Default Re: 1993 Honda Civic DX Question (diego)
well first off all your clutch is hydraulic sooo...u dont have a cable to snap! 2nd of all i would check to see what CEL codes your throwing... and if your clutch pedal is stuck at the floor it would still start!
Old Sep 5, 2004 | 02:12 PM
diego's Avatar
Default Re: 1993 Honda Civic DX Question (JDMisGOOD)
Okay i didn't know that. I'll do some searches on Check Engine Light Codes as I haven't done that before. Thanks.
Old Sep 5, 2004 | 02:23 PM
JDMisGOOD's Avatar
now u do! using the search key...Good plan!
NataSS Inc
Aug 13, 2015 02:53 PM
RobTimmerman
13
Jun 30, 2014 08:21 PM
raider1qaz
10
Jan 30, 2014 07:06 PM
sometimeswhy
31
Apr 1, 2013 11:31 AM
bale43kn
10
Apr 25, 2007 07:59 AM
