Remove camshafts then reinstalled and didn't use assembly lube... Would it cause bad idle?
Old Sep 5, 2004 | 12:03 PM
integmester's Avatar
Default Remove camshafts then reinstalled and didn't use assembly lube... Would it cause bad idle?
I just removed my camshafts and when i reinstalled it i didn't use assembly lube. Would that cause my car to idle bad?
Old Sep 5, 2004 | 12:28 PM
Jim Truett's Avatar
Default Re: Remove camshafts then reinstalled and didn't use assembly lube... Would it cause bad idle? (inte
It could if the lack of lubrication on initial startup caused the bearing journals to gall.
Old Sep 5, 2004 | 01:58 PM
beaterdriver's Avatar
did u make sure the cam gears are lined up correctly?
Old Sep 5, 2004 | 02:17 PM
Default Re: (beaterdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterdriver &raquo;</TD></TR><TR><TD CLASS="quote">did u make sure the cam gears are lined up correctly?</TD></TR></TABLE>
both timing marks are at TDC...
Old Sep 5, 2004 | 02:31 PM
is the white mark on the crank pully lined up with the dash on the plastic trim?
Old Sep 5, 2004 | 02:38 PM
did u adjust ur valves?
Old Sep 5, 2004 | 05:42 PM
fulldragcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beaterdriver &raquo;</TD></TR><TR><TD CLASS="quote">did u adjust ur valves?</TD></TR></TABLE>
ding ding ding, we have a winner, tell him what theve won jonny.
ive had cars not start, not idle etc. cause of improper valve clearence .
Old Sep 5, 2004 | 06:20 PM
Default Re: (fulldragcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fulldragcrx &raquo;</TD></TR><TR><TD CLASS="quote">ding ding ding, we have a winner, tell him what theve won jonny.
ive had cars not start, not idle etc. cause of improper valve clearence .</TD></TR></TABLE>
he won a valve adjustment w00t.
Old Sep 6, 2004 | 04:03 AM
timing mark on the timing belt cover lines up to with crank pulley...
I have crower 402s and did valve adjustments to crower 402 specs which is .006 int. hot and .008 exh. hot... still bad idle...
Old Sep 6, 2004 | 07:11 AM
93civicEX's Avatar
Hmm, I think that is a big cam, so no matter what you do, you are still going to get a bad idle.
Old Sep 6, 2004 | 07:31 AM
mmuller's Avatar
Mad Scientist
did you reset your ignition timing?
Civic Hybrid
27
May 29, 2006 04:02 PM
GSRfoedoe
10
Feb 21, 2006 04:18 PM
civic_eh
Dec 30, 2005 05:18 PM
94IntegraLs04
Oct 1, 2005 11:18 PM
crxste
10
Feb 28, 2005 09:18 PM
