What CR for Skunk2 Stage3 cams
Old Sep 5, 2004 | 09:33 AM
1quickhatch's Avatar
Default What CR for Skunk2 Stage3 cams
Does anyone know what CR is recommended for these cams? I've been told at least 13.1 by a couple of people but none of them have ever worked with the cams.
Old Sep 5, 2004 | 07:51 PM
Default Re: What CR for Skunk2 Stage3 cams (1quickhatch)
Bump. Anyone???
Old Sep 6, 2004 | 01:48 PM
anothersickhatch's Avatar
anything above 12.5 should give you some pretty good numbers.
in my opinion, 12.5 is the compression ratio where stage 2's are still good, but stage 3's are a little better.
Old Sep 6, 2004 | 06:27 PM
Default Re: What CR for Skunk2 Stage3 cams (anothersickhatch)
So how about something in the 14 plus CR area?? Would this be too much?? Also what bore would be the minimum required?
Old Sep 6, 2004 | 09:25 PM
murtnabila's Avatar
14 plus would be kool. You're not using it for street, right?
Old Sep 6, 2004 | 10:52 PM
Archidictus's Avatar
Unceasing Measure
Default Re: What CR for Skunk2 Stage3 cams (murtnabila)
Watch for valve-to-piston clearance with a 14.0 : 1 compression ratio when you're at high RPM. I'm not saying it's impossible on a stock crank and headgasket, but plastigauge and putty those pistons and valves before you fire it up .
Old Sep 7, 2004 | 10:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murtnabila &raquo;</TD></TR><TR><TD CLASS="quote">You're not using it for street, right?</TD></TR></TABLE>
No, not really. But it'll remain with the complete body for now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Watch for valve-to-piston clearance with a 14.0 : 1 compression ratio when you're at high RPM. I'm not saying it's impossible on a stock crank and headgasket, but plastigauge and putty those pistons and valves before you fire it up .</TD></TR></TABLE>
So 13.5.1 would be a pretty good in between, right? What about the bore of the block. I'm thinking of sleeving the LS block to 85mm and going with the 13.5.1 CR for now. How's that sound for a first project. Maybe I'll take it to the street once in a while with VP gas, just to see people's faces. HEHE
Old Sep 7, 2004 | 12:07 PM
gsrjay's Avatar
I had skunk 3 cams in my motor 2.0l gsr with 12.5:1 je 85mm pistons.Head fully built and ported skunk manifold etc.Going to try a set of skunk stage 2's and see how I do.Be carefull when playing with the cams on the dyno as clearance becomes an issue.
Old Sep 8, 2004 | 03:27 AM
Default Re: What CR for Skunk2 Stage3 cams (gsrjay)
How much hp did you get?? Did the cams respond good to timing?? does anyone know the mm a GSR head measures when completely stock?? I'd like to know how much was milled from mine.
Old Sep 8, 2004 | 04:35 AM
gsrjay's Avatar
The motor made 203 whp with my old setup with the mid endyne roller waves 12.1:1 then broke a piston from an injector going bad.At that time my cams were +4,+4.MY head has also been milled but not sure how much.I hope these skunk 2 stg 2's make good power even though I'am going to a smaller cam.
Old Sep 8, 2004 | 06:46 AM
What other mods did you have? IM, header, ecu, injector cc's, knifed crank etc.....
Old Sep 8, 2004 | 01:37 PM
gsrjay's Avatar
ported skunk 2 manifold,smsp 2.0l header,rc 310cc injectors,p28 chipped ecu by local tuner,oversized valves.
vitalik
Sep 15, 2006 01:32 PM
got_boost16
24
Jan 27, 2006 12:26 PM
Got Milk
15
Nov 13, 2005 10:05 AM
dabomb
Mar 24, 2003 03:31 PM
