tdc sensor?
i just did a dohc zc swap into a 91 crx si. everything went well but it came time to start it and it wont start. it turns over and when i give it gas is sounds like it wasnts to start. its giving code 8 for top dead center sensor? anyone have any clue what could be wrong?
thanks
thanks
its a distributor i got the with dohc zc swap.. also i double checked the timing and its not off.. but the timing belt keeps sliding off of the cams and the crank, not completely off just about half way off..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juanb »</TD></TR><TR><TD CLASS="quote">its a distributor i got the with dohc zc swap.. </TD></TR></TABLE>\
The ZC dizzy has a 5pin connector, your D16A6 dizzy had a 7 pin. Did you remove the correct 2 wires and run them to the crank angle sensor on the ZC's exhaust cam?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juanb »</TD></TR><TR><TD CLASS="quote">but the timing belt keeps sliding off of the cams and the crank, not completely off just about half way off.. </TD></TR></TABLE>
That's just not right
Did you reset the manual tensioner correctly after setting timing?
h22_crx
10
Nov 11, 2005 11:52 AM
89civich22
Oct 17, 2005 05:50 PM
Crx-Racer4Life
10
Jul 1, 2004 12:38 PM
but its up and running now thanks
