01 Accord Coupe - T/Belt and Water Pump Replacement???
How many miles/kilometers should I wait until I replace my timing belt? Also I've been told that when your getting the the belts replaced might as well do the water pump as well - is this correct?
Thanks...
Thanks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sj993 »</TD></TR><TR><TD CLASS="quote">I've actually heard it's best to replace the timing belt and water pump at the same time.</TD></TR></TABLE>
yes, because the water pump and gasket is dirt cheap but the labor is mad expensive, if you gonna take out the belt when you doing the timing belt, swap out the old, beat up water pump while you at it, you'll save on labor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sj993 »</TD></TR><TR><TD CLASS="quote">I've actually heard it's best to replace the timing belt and water pump at the same time.</TD></TR></TABLE>Yes, we normally replace the pump with the belt just because we're already there. Nothing pisses a customer off more than paying for a water pump, 6 months after the timing belt was replaced.
Is this a 6-cyl or 4-cyl? They have slightly different recommended intervals.
If you need OEM parts, let me know. I should have everything in stock.
Thanks for the notice...
I have 2 cars I'm looking at:
1) 01 accord coupe 4cyl. 5spd.
and
2) 96 civic hatchback auto.
just curious to know the OEM parts cost for both T/belt and water pump on both vehicles...thanks.
and
njracer
Jan 10, 2008 05:07 PM
spluvs2install
Aug 26, 2006 07:40 PM
1998hondaaccord
Sep 18, 2003 05:00 PM
