codes???
Old Sep 5, 2004 | 07:07 AM
noob2k's Avatar
Default codes???
ok i know how to read the flashing light when my crx was stock but i did a obd1 ecu swap and put in a d16z6 wont turn over check engine light comes on now how do i check for codes with the p28 ecu on a dx crx with a d16 in it
thanks for all the help guys
Old Sep 5, 2004 | 09:40 AM
blo2k1's Avatar
Default Re: codes??? (noob2k)
anyone know how to do this?? just need to know why i have check engine light need to check codes dont know how because of the swap
Old Sep 5, 2004 | 09:43 AM
noob2k's Avatar
Default Re: codes??? (blo2k1)
thanks bro for bumping the post if we cant get it running well have to go to autocrafting thanks for helping with the swap as much as you have have fun in long island
Old Sep 5, 2004 | 10:34 AM
Origin's Avatar
did you guys hook up a toggle switch? this is how i check my car if it throws any codes.
Old Sep 5, 2004 | 10:35 AM
noob2k's Avatar
Default Re: codes??? (Origin)
no we didnt how do you do that???
tell us how and do you have code sheets?
Old Sep 5, 2004 | 10:42 AM
4drEF's Avatar
Keyboard Humorist
I'm not sure how you converted to OBD-1, but if you did the wiring yourself and did it correctly OR if you got a quality jumper harness then it's really easy.
You just put a jumper (paperclip) in the 2 prong connector under the glovebox.
It's the same connnector you put a jumper in when you go to set the ignition timing.
Search Yahoo! for HONDA ECU CODES and you should find MANY links to what the codes mean.
Old Sep 5, 2004 | 10:43 AM
noob2k's Avatar
Default Re: codes??? (4drEF)
i bought a locash racing jumper harness with dizzy adapter and subv harness for vtec
Old Sep 5, 2004 | 10:47 AM
Origin's Avatar
on my harness there is a wire running from the jumper which can hook a toggle switch up to, ground the toggle switch and when you have a cel you switch on the toggle switch (ground it) and it will show you the code. that would be the same thing as jumping it with a paper clip but instead of using a paper clip you are using a toggle switch.
Old Sep 5, 2004 | 12:08 PM
noob2k's Avatar
ok we did it got code 4 and 41
Old Sep 5, 2004 | 12:10 PM
noob2k's Avatar
bump for help
dwf
Mar 11, 2009 12:26 PM
SmogKing
Aug 3, 2006 12:48 PM
Sl0wEK
Feb 12, 2005 03:18 PM
egLs20
Sep 21, 2004 04:26 AM
