Test results for the Hondata Heatshield Gasket
Old Dec 6, 2001 | 11:58 AM
Hondata's Avatar
Default Test results for the Hondata Heatshield Gasket
The test results are in - independantly verified.
http://www.hondata.com/dynoh22agasket.html
10-25 degree F drop in intake temperature.
40 Degree drop in manifold surface temperature.
5 HP (3%) increase in power.
Now available for the D16Z and S2000. (as well as the B16, B18 and H22)
General info here: http://www.hondata.com/heatshield.html
Extensive fitting guide and test results here:
http://www.s2000.org/mods/insulator/
Doug
[Modified by Hondata, 12:59 PM 12/6/2001]
Old Dec 6, 2001 | 12:33 PM
DIRep972's Avatar
Smarter than you
Default Re: Test results for the Hondata Heatshield Gasket (Hondata)
Damn for 60$ thats not a bad deal at all, ill probably get one of those when I change out my intake manifold..
Old Dec 6, 2001 | 02:05 PM
TurboSedan's Avatar
New User
Default Re: Test results for the Hondata Heatshield Gasket (DIRep972)
3% gain for $60 is well worth it! Good product!!
Old Dec 6, 2001 | 03:55 PM
schwett's Avatar
New User
care to comment on the difficulty and time involved in installing this piece on a prelude? i picked the gasket up, knowing the install would be a PITA, but i think i underestimated just how bad it would be.
have you done or do you know of anyone who has added this to a JRSC'd prelude after the fact? (i.e. not at the same time as the kit install)
Old Dec 6, 2001 | 07:05 PM
FAST94GSR's Avatar
New User
Default Re: Test results for the Hondata Heatshield Gasket (schwett)
think its worht as long as you don't live in a cold climate. don't have to worry bout that here, sheesh it is still 82 degrees here.
put me down for one
Old Dec 6, 2001 | 08:12 PM
InfamousRS's Avatar
Default Re: Test results for the Hondata Heatshield Gasket (FAST94GSR)
Thats kinda funny, In one of the Import Mags this month, they did a bolt on build up of a 1994 Acura Integra LS. They instaled a greddy Cat Back exhaust, Injen Intake, and a header of some sort. They only gained 4.5 hp, and it cost around a $1000.00!!!!!
Would Hondata gasket work for any gains on a non boosted engine?
Old Dec 7, 2001 | 09:44 AM
Hondata's Avatar
Default Heatshield Gasket for the NA engine
It works just as well. Read the results on the S2000 in the initial post.
Apr 7, 2009 08:04 AM
patastinky
Dec 4, 2004 07:32 AM
DanielLaruso
Feb 4, 2003 05:28 AM
ViZ
Aug 21, 2002 01:47 PM
IntegraT
Dec 7, 2001 07:56 PM
