benefits of a valve adjustment
Old Sep 4, 2004 | 09:59 PM
foolintherain617's Avatar
Default benefits of a valve adjustment
My DA seems to be running pretty good, but it is 15 years old and could probably use a tune up. Everybody keeps say valve adjustment. What benefits will i get from doing this and how much does an average one cost?
Yes I Searched
Thanks
Old Sep 4, 2004 | 10:47 PM
shermanyang's Avatar
Default Re: benefits of a valve adjustment (foolintherain617)
usually you'll yield better flow and/or better compression as your rocker arms and cams are probably worn and out of spec. i'm not sure how much honda or other places will charge for doing one so i can't help you out there. i personally would read up about it somewhere and figure out how to do one. it's actually very easy to do...but it will take about 30min though.
Old Sep 4, 2004 | 10:49 PM
iwannaboostmyteg's Avatar
like he said you'll notice a difference and the car will run smoother. I just had mine done like a month ago and my car runs way better and the annoying ticking noise from having loose valves is gone so thats always a plus.. I recommend adjusting your valves atleast before every summer as it can be hot and loose valves isn't a good thing to have during the summers heat.
Old Sep 4, 2004 | 11:25 PM
xprohx's Avatar
I think too much
Default Re: benefits of a valve adjustment (iwannaboostmyteg)
I recommend having them done, if not to get a smoother feeling car, than do it for peace of mind.
Old Sep 5, 2004 | 02:07 PM
Sounds good. Thanks a lot
Peruviann83
Mar 30, 2007 10:10 AM
DraginTeg93
Dec 29, 2006 10:11 AM
b20integrapower
Feb 9, 2006 07:12 PM
lilxvtecxpwr
11
Sep 17, 2002 05:58 PM
