wont rev
hey whast up i did a d15b sohc vtec swap but it wont rev over 3,500 rps whats the deal does any one have any good ideas to look into or has anyone had this problem??? need help checked my connections dist cap rotor plug wires and injectors
thanks alot please help
brent
brent
im running a p28.............it runs great till it hits 3500 rpms idels great ...........no vaccum leaks, timing is great hot or hot or underload or not it still bounces off the rpms at 3500 almost like a rev limiter at 3500
any ideas
brent
keep the ideas coming
any ideas
brent
ok i took it down the road for another test drive 1st took it 3500 bounced off what feels like a rev limiter and it did this all the way till 5th gear
this swap is driving me nuts
you guys helping me
you guys helping me
its on limp mode, u have something wrong in wiring or jumper, once u get that problem solved that will go away, but u need to figure out whats wrong....yuo should be throwing CEL's when ur on limp mode...so check for that...if you cant check them....ur going to have a fun time....
Check your timing. I had the same problem you are describing and wound up bending a valve. I repeat check you timing. If you are off a tooth then your car will only rev to 3500.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noob2k »</TD></TR><TR><TD CLASS="quote">timing was adjusted to spec still throwing codes for o2 and crank angle not too worried bout o2 but crank angle not sure sounds like some $$$$
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 »</TD></TR><TR><TD CLASS="quote">So its not throwing any codes?CEL whatsoever?</TD></TR></TABLE>
Come on... atleast read the post's. I am not a expert on these swaps but I just read a post a while back that you were sopposed to run 2 wires to the crank angle sensor. Maybe from the Dizzy?
Yuup... from what I understand: the stock Dizzy has that sensor in it. But with your hybrid... maybe that sensor is somewhere else...
Again, dont quote me on this... but I would try searching.
did you ever figure out why your car didn't rev more that 3500? i am having the same problem, and i can't figure out what to do, i have tried everything i can think of so any helpful advice would be much appreciated.
no its still doing it i e-mailed locash and they said my dizzy was wired wrong ??? well i hope so cause i tried like every combination they said go to the junk yard and get a hf or si harness side 7 wire plug for the dizzy and use the adapter they gave me to plug it into the obd1 dizzy
brent
hope he is rite or im givin up gonna pay to get it done
brent
i had the same problem , my problem was when i put the gas pedal to the floor it would bogg its a$$ off at 3500. to fix it u will have to swap the 2 outer tps wires and while you are at it just check the tps over to make sure it is not broken. if i am not mistaken that will fixx ur prob. hope i helped
problem still not solved posting some pics of the ride so hopefully it will ecourage some good ideas
[IMG][/IMG]http://www.we-todd-did-racing.com/wetoddimage.wtdr/wNTUxMjc2NnM0MTNkZmQzMXk1NDE%3D.jpg
[IMG][/IMG]http://www.we-todd-did-racing.com/wetoddimage.wtdr/wNTUxMjc3NnM0MTNkZmQzMXk1NDE%3D.jpg
harnes--dizzy
peach ----------------white
white/blue------------white blue
c1 for mpfi-----------blue/yellow
thin white wire-------peach
peach/blue-----------peach blue
c2 for mpfi------------blue
fat white--------------yellow/green
this is how we have it hooked up now we tried to move around c1 and c2 and thin and thick white but nothing else
help
thanks
help
thanks
