ls/vtec crower stg 3 cammed dyno...
Old Sep 4, 2004 | 03:10 PM
Toda Party's Avatar
Default ls/vtec crower stg 3 cammed dyno...
Hit up the dyno today, we were moving along, had the intake cam at +2 advance, exhaust at +2 advance, however the head and deck have been milled an unknown amount so... prolly need to play around with the cam timing some more.. we were going to do some more pulls when his distributor took a crap on us, he's got no luck with obd0 distributors lol..he's getting a brand new one from distributor king soon..a/f still needs a slight clean up here and there
ls/vtec ~12.5:1 compression
81.5mm bore
gsr head w/crower stage 3's (light port polish)
skunk2 intake mani stock throttle body
stock rods(arp bolts) and stock oversized itr pistons.
Im sure theres other stuff Im forgettnig but that pretty much sums it up.
run 3 is baseline what we came in with after some rough street tuning
run 7 is where we made the best power at +2 +2 before the dist died
torque really dies off in the top end, probably due to the ignition timing, max advance at the distributor all the way cranked to advance was only 15*, and this is tuning via VAFC
check out that gain in the midrange
here's crower's results with the same cams
judging from the results from crower, we're not going to get too much more top end out of em, tq falls off just like john's did today..altho with the higher compression we should see some better numbers once the cams are dialed in and the timing is bumped up a bit, dunno whether to be dissapointed or satisfied, but its we're not done tuning it yet...
Old Sep 4, 2004 | 03:24 PM
non-VTEC's Avatar
Default Re: ls/vtec crower stg 3 cammed dyno... (Toda Party)
which stage 3's did you run?
they have 2 diffrent stage 3's for the DOHC VTEC engine....the 63413 or the 63403?
not bad numbers i guess....i would imagine they could use some more tuning....
Old Sep 4, 2004 | 03:41 PM
Toda Party's Avatar
Default Re: ls/vtec crower stg 3 cammed dyno... (non-VTEC)
im not sure, its not my car...im hoping like 190's when all's said and done
Old Sep 4, 2004 | 03:59 PM
vtec69's Avatar
Nice
thats almost the same setup that i had in my ls/vtec
I loved those cams
Old Sep 4, 2004 | 04:27 PM
jdmcx's Avatar
Default Re: ls/vtec crower stg 3 cammed dyno... (vtec69)
the 63413 are some really nice cams i have a brand new set sitting here that i am trying to get rid off i would keep them but i need to pay some money on my school bill
Old Sep 4, 2004 | 05:13 PM
vtec69's Avatar
Default Re: ls/vtec crower stg 3 cammed dyno... (jdmcx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcx &raquo;</TD></TR><TR><TD CLASS="quote">the 63413 are some really nice cams i have a brand new set sitting here that i am trying to get rid off i would keep them but i need to pay some money on my school bill</TD></TR></TABLE>
are those vtec cams?
I thought the vtec cams were 63403
Old Sep 4, 2004 | 05:40 PM
pro4machine's Avatar
I have heard those crower cams are not that good. Try some skunk2s or jun3s
sounds like from what I have read on this forum that your almost at stock power.
Old Sep 4, 2004 | 08:07 PM
turbociv's Avatar
the cams are the 63403's. Im not too sure whether or not to be happy with my gains here either.
Old Sep 4, 2004 | 09:52 PM
DefiantGSR's Avatar
what kind of header?
Old Sep 5, 2004 | 04:06 AM
turbociv's Avatar
header is a jdm dc 4-1. Not really in the beswt shape either. Im thinking a free flowing 2.5 exhaust will help but by how much? Maybe even a throttle body? I mean I guess im kinda close to my goal mark. But it just seems like the numbers are kinda low.
Old Sep 5, 2004 | 05:42 AM
jdmcx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 &raquo;</TD></TR><TR><TD CLASS="quote">
I thought the vtec cams were 63403</TD></TR></TABLE>
yes they are there are two types of vtec cams the original 63403 and the new 63413 the only difference is that the new ones have bigger primary lobes
Old Sep 5, 2004 | 10:31 AM
DefiantGSR's Avatar
Default Re: (turbociv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociv &raquo;</TD></TR><TR><TD CLASS="quote">header is a jdm dc 4-1. Not really in the beswt shape either. Im thinking a free flowing 2.5 exhaust will help but by how much? Maybe even a throttle body? I mean I guess im kinda close to my goal mark. But it just seems like the numbers are kinda low.</TD></TR></TABLE>
numbers do seem low with that compression and those cams. a good header will net you ~5whp up top and a better midrange(just a guestimate).
Old Sep 5, 2004 | 11:46 AM
shant's Avatar
Default Re: (DefiantGSR)
I would think the numbers would be higer with such aggressive cams.
181 whp. 81mm PR3 pistons 11.3:1cr, ls vtec, stock type R head, stock intake manifold, type R cams. jdm dc 4-1, field vtec controlder tuned.
Old Sep 5, 2004 | 12:27 PM
spartacus087's Avatar
Default Re:
roclife?
Old Sep 5, 2004 | 07:04 PM
turbociv's Avatar
Default Re: (shant)
I agree. Numbers should be higher but my distributer was probably cutting out during tuning, and I couldnt advance more than 14 degrees. I need to find out a way to tune obd0 ecus. Im not about to convert to obd1 when the season is almost over. Maybe over winter but not now. How can I adjust my timing/fuel??? Chrome maybe?? anything better?? Im kinda stuck with this mugen n1 program and Im starting to wonder if its not quite right for my setup.
Any recommendations??
What were your setting shant?? what was your timing, overall timing, cam gear settings, etc etc. Your setup is very close to mine but I have yet to yield any good numbers.
Old Sep 5, 2004 | 08:56 PM
.derf.'s Avatar
my set up was around the same and made 208hp and 140trq
12.5 to 1 compression je pistons and eagle rods
gsr head with rev springs and retainers
crower stage 3 cams
skunk intake manifold
shitty 4-1 dc headers
310cc injectors
stock throttle body
tuned with a feilds afc
afr was around 11.5-12.0
timing was at 18 deg
Modified by hybridKOOPHRI at 6:16 PM 9/7/2004
Old Sep 5, 2004 | 10:30 PM
Dancing is Forbidden's Avatar
Default Re: ls/vtec crower stg 3 cammed dyno... (hybridKOOPHRI)
I dont see why 190s arent out of reach with that setup. GL with it!
Old Sep 6, 2004 | 02:43 AM
yaya's Avatar
wow that seems super low for such extensive work. it seems low becaue a stock b18cr makes roughly 175 whp with no mods at all. all that work and no one is even breaking 200whp? i hope that your tuning it ***-backwards.
good luck man!
sounds like a serious set of parts in that biatch
Old Sep 6, 2004 | 03:54 AM
turbociv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridKOOPHRI &raquo;</TD></TR><TR><TD CLASS="quote">my set up was around the same and made 197hp and 140trq
crower stage 3 cams
310cc injectors
stock throttle body
timing was at 18 deg</TD></TR></TABLE>
what kinda car, ecu, program. etc etc.
Old Sep 7, 2004 | 05:15 PM
.derf.'s Avatar
Default Re: ls/vtec crower stg 3 cammed dyno... (turbociv)
the set up was in a 94 dx coupe(lightend up)
skunk 2 ecu
running just a greddy resonator, no muffler
injen cold air with no filter
type r flywheel, gsr tranny
car went 12.49@109
Old Sep 7, 2004 | 06:01 PM
turbociv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridKOOPHRI &raquo;</TD></TR><TR><TD CLASS="quote">the set up was in a 94 dx coupe(lightend up)
skunk 2 ecu
car went 12.49@109</TD></TR></TABLE>
All that untuned???? Damn, I wish something would just work out here. Any suggestions??? I could probably hit 12's the way it sits now but thats not good enough for me. So Far I went 8.36 at the local 1/8 track. GRRRRRRR, Im frusterated. LOL
crcale
30
Jul 11, 2011 05:17 PM
Mach slo
25
Oct 22, 2003 12:03 AM
freakifran
Jul 12, 2003 02:53 PM
[HrZn]4life
Jul 3, 2003 06:35 PM
PrecisionH23a
Dec 3, 2002 02:25 PM
