NEED HELP ASAP-LS VTec T3 smoking to much
Old Sep 4, 2004 | 01:18 PM
elusive123's Avatar
Default NEED HELP ASAP-LS VTec T3 smoking to much
Just got done my LS V Tec turbo swap...... B18B with B18C head. Oil is coming from exhaust ports leaking into the manifold, causeing very large amounts of white smoke to pour from the exhaust. I replaced valve stem seals did not adjust valves yet. Compression is 150 or better all across the board, coolant level is good all LS V Tec lines are hooked up properly.Engine is running good car idles at 1000 steadily and strong, I have a lynksys controller if that helps but I don't think it will , I could really use some help asap.
Old Sep 4, 2004 | 01:39 PM
jlv55's Avatar
Default Re: NEED HELP ASAP-LS VTec T3 smoking to much (elusive123)
who turbos a ls/vtec? seriously man. how reliable could it be?
carlossolorzano
Jun 29, 2011 12:30 PM
turbodelsolb16a2
Jan 27, 2010 05:15 PM
JDM92da6
Oct 16, 2009 12:21 AM
g2lsv
Dec 8, 2005 01:13 PM
