Help !!! wiring question
I am maping out the wiring for the ITR cluster and had a few questions on the C connector (10 pin). The info below i got from the helms integra service manual, which gave very vauge info on the C connector. It appears to be for automatic tranny gauge clusters. I was wondering if any of your Type R's have any wires going to that connector? Also if anyone could tell me what fuse #15 (10a) and #24 (15a) say they do, they are in the under dash fuse box. I am putting the ITR cluster in my ef, just trying to figure out these last little things. Any info is appriciated. TIA
Chris
B 1 RED/BLU Seat Belt reminder
B 2 LT GRN / RED Door Open Indicator
B 3 YEL / WHT Fuel Gauge
B 4 BLU / WHT Low Fuel
B 5 NONE No Function
B 6 ORN Speedometer
B 7 GRN Hatch Latch Indicator
B 8 NONE No Function
B 9 RED Dash Lights Dimmer
B 10 RED / BLK Fuse (10 A)
B 11 BLK / YEL Under dash fuse #24 (15 A)
B 12 NONE No Function
B 13 GRN / BLU Left Turn Signal
B 14 GRN / YEL Right Trun Signal
B 15 RED / GRN High Beam Indicator
B 16 GRN / RED Brake System Light
C 1 ? ?
C 2 ? ?
C 3 LT GRN / BLK TCM
C 4 GRN / WHT Park
C 5 GRN / RED Reverse
C 6 GRN D3
C 7 GRN / BLU D3
C 8 GRN / YEL AT GEAR 2
C 9 LT GRN / WHT AT GEAR 1
C 10 GRN / BLK TCM
D 1 NONE No Function
D 2 PINK Maintenance Reminder Light
D 3 NONE No Function
D 4 YEL Fuse #15 (10 A)
D 5 NONE No Function
D 6 BLK G201 / G401
D 7 YEL / GRN Coolent Temp
D 8 NONE No Function
D 9 WHT / BLU Alternator
D 10 NONE No Function
D 11 YEL / RED Low Oil Pressure Indicator
D 12 GRN / ORG Malfunction Indicator
D 13 BLUE Tachometer
If anyone knows what the 5spd mappings are for the C cluster please fill them in !
Chris
B 6 ORN Speedometer
C 1 ? ?
C 2 ? ?
C 4 GRN / WHT Park
C 6 GRN D3
C 7 GRN / BLU D3
C 10 GRN / BLK TCM
D 6 BLK G201 / G401
If I were you I would IM Katman. His friend Dylan I hear did a horribly difficult install of an EK cluster into his civic. Might be able to point you in the right direction......
*shrug*
EDIT-That is unless someone here has the information he's looking for... TTT
[Modified by sackdz, 2:46 PM 12/6/2001]
*shrug*
The G2 Racer
Oct 18, 2002 02:38 PM
