Help: Air idle wire problem
i got a 97 civic dx and i put a 95 civic ex intake manifold on it. i extended the map, tps, air intake temp sensor, and all nessary sensors except the only problem i have is the air idle control valve on the dx harness has 3 wires and the new aicv only is a 2 wire plug. i switched up wires like its my job and nothen works right. anyone have a wire diagram that tells colors and what they do or has anyone know what to do here? i was thinkin bout switchin the 2 so the dx one is on the ex mani. any help would be appreciated!
any1 out there? come on im dyin here. i just ****** did a auto to manual swap n all this bullshit n now it comes down to a 3 wire to 2 wire harness. anyone? help
in my haynes manual the 3 clolors u should have is orange, yel/blk, blk/blu on your old harness. thats what is shows for an automatic dx 97. since you got an older mani. and a maual trans now u should use the yel/blk and the blk/blu, i think u need to switch the pin for the blk/blu wire on the ecu between colors orange and red /yel to where the iac v is located on the ecu between wire colrs yel/blk and orange. 2 pin spaces over. there should be a blk/blu wire there u can splice the old blk/blu wire onto but if not u may have to pull out the pin and switch it to the new pin location. i have not done one of these before but, try using the yel/blk, and blk/blu first and see how the car runs. if not then u might have to do the pin change. hope i helped somewhat.
yea im still usin the dx ecu but im gettin my buddies manual one cuz im already throwin a cel for auto trans. i didnt want to spend money on this car or atleast not to much thats y i was tryin to stick with wat i got. the car is gonna be 4sale soon n i just wanted to get it runnin propper. thanx 4 ur input guys
Chaosgrunt
Mar 13, 2019 06:23 PM
KiNG $h!t
Jan 30, 2005 09:45 PM
