Fog light help!! ('99+ EK)
installed my fogs in my '00 Si. Worked fine for about 3 weeks. then one day they just stopped working.
So far i've done the following:
Checked both bulbs - neither are blown, both in good shape, only used 3 weeks.
Checked all fuses - none blown
Checked connections to fog lights and harnesses - cant see anyting visably wrong?
Now, my question is, what should i do to keep trouble shooting? im thinking perhaps a ground im using isnt good?
The ground wire they supply is very short and is meant to go to some bolt behind my dash, it was a pain in the *** so i used a different bolt. my question is this: can i just cut the "loop" off of the end of the ground, splice in about 4 more feet of wire and find a more accessible ground some place else? does the length of the ground wire hinder the electrical output?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Vapor »</TD></TR><TR><TD CLASS="quote">can i just cut the "loop" off of the end of the ground, splice in about 4 more feet of wire and find a more accessible ground some place else? does the length of the ground wire hinder the electrical output?</TD></TR></TABLE>
Sure, you can do that and it won't hinder the the electrical output.
Did you check the actual switch? Sometimes they can go bad..
93CharcoalHatch
25
Dec 6, 2005 01:20 PM
esoterEK..
14
Aug 18, 2004 12:44 PM
