flywheel bolts
Old Sep 4, 2004 | 08:43 AM
dat_flip's Avatar
Default flywheel bolts
Ok i already searched. I just got done putting my tranny on the engine (they are still out of the car). I just wanted to know if i should have used loc tite on the flywheel bolts. I did torqued them to spec in a crisscross patern, I just wanted to make sure if it was gonna be safe without using loc tite on the bolts? Thanks in advance.
Old Sep 4, 2004 | 11:45 AM
agturbo's Avatar
Default Re: flywheel bolts (dat_flip)
I never use loctite on mine and have never had problems with them coming loose, as long as you have them torqued to spec you should be fine..
Old Sep 4, 2004 | 01:29 PM
DonF's Avatar
Default Re: flywheel bolts (agturbo)
Sounds like you did it correctly, go ahead and install.
Old Sep 4, 2004 | 05:25 PM
dfoxengr's Avatar
no you dont need to. there wasnt any on there from the factory was there....
jrsh0526
Jan 24, 2014 06:27 PM
s2k_al
Feb 19, 2005 11:41 PM
preluda92
Aug 30, 2003 02:29 AM
89civic1.8T
Mar 25, 2002 08:15 AM
