ek water in trunk
Old Sep 4, 2004 | 07:53 AM
quagabow's Avatar
Default ek water in trunk
every time it rains water seems to get into my trunk and pool around the spare tire. I have a 97 coupe with a factory spoiler. Does anyone know where the water is coming in or has dealt with this problem before. I'm gettin tired or shop vaccuming out my trunk after each storm. Thanks.
-Jesse
Old Sep 4, 2004 | 08:17 AM
HaTcH_BmX's Avatar
Default Re: ek water in trunk (quagabow)
did you check if all the rubber pieces are in good shape??
i had the same problem in my eh2 last year untill i changed those rubber pieces around the hatch
Old Sep 4, 2004 | 08:54 AM
quagabow's Avatar
Default Re: ek water in trunk (HaTcH_BmX_Ep3 kid)
the rubber around the trunk is in good shape and the rubber for the spoiler seems fine as well...that is why i'm baffled at the source of this problem.
Old Sep 4, 2004 | 08:56 AM
ooairewreckoo's Avatar
holy crap i got the same damn problem. WTF!!!! i was thinking of drilling a small hole to drain it. but i didnt wanna bother. someone help ... to the top.
Old Sep 4, 2004 | 09:01 AM
quagabow's Avatar
Default Re: ek water in trunk (ooairewreckoo)
yeah i was tempted to drill a drain hole but figured that would just start some crazy rust in my trunk...if anyone has a solution please help us out.
Old Sep 4, 2004 | 09:06 AM
Dino_D's Avatar
Probably the tail light gaskets.
Old Sep 4, 2004 | 09:09 AM
deSigi's Avatar
I found out why water was coming into my ek trunk... When you open the trunk, look towards the left side. It's a plastic vent that is underneath the carpet (or whatever it is). You can also remove the rear bumper and examine it from that angle. Mine seems to be loose somehow. I can't push it in properly for it to seal the hole. That's where I noticed the water was coming from.
Maybe we just need to replace that vent?
Hope this helps.
Old Sep 4, 2004 | 09:18 AM
quagabow's Avatar
Default Re: (deSigi)
thanks desigi...i'll check that. As for tail light gasket, i bought red/clears and replaced the gaskets so i don't think that is where my problem lies but thanks for the suggestion. Really hope it is that plastic piece.
-Jesse
Old Sep 4, 2004 | 09:46 AM
POE's Avatar
POE
i also have a problem with leaking in my trunk but it doesnt sound like the same problem, mine comes in from both sides on the side of the trunk then leaks into thespare tire area. i think it may be the seal around the top of the trunk but it seems to be coming frombehind the carpet up inside the body of the car right under neith the rear windows.
Old Sep 4, 2004 | 09:54 AM
Mr. Vapor's Avatar
Default Re: (Vtecin94dx)
i TOO have the same problem in my '00 EMI coupe.........ill try to investigate
Old Sep 4, 2004 | 10:59 AM
The Mista Mike's Avatar
Default Re: (Mr. Vapor)
Same problem... makes my car smell like poo...
Old Sep 4, 2004 | 11:16 AM
EK k kay's Avatar
Default Re: (Mistamike17)
I found some water in my ek hatch trunk in the same area too. Only happened once though. It rained really hard another day, but no water inside.
Old Sep 5, 2004 | 08:59 AM
deSigi's Avatar
I've seen so many people with this very same problem. I'm not too sure what they do to fix this. Some only have to replace the taillight gasket, others drill a hole in the trunk to let the water out... I don't know what kind of effect that could have though.
Old Sep 5, 2004 | 09:05 AM
Ricey McRicerton's Avatar
Default Re: ek water in trunk (Sc2_Dan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sc2_Dan &raquo;</TD></TR><TR><TD CLASS="quote">Probably the tail light gaskets.</TD></TR></TABLE>
That's my guess as well.
Old Sep 5, 2004 | 09:52 AM
h22ejcoupe
Guest
Posts: n/a
I had this same problem in my 95 civic coupe and it was due to small holes caused by rust in the wheel wells. After stripping the back of the trunk apart I noticed the water was coming in from there on rainy days, due to the spray caused when the car is in motion. Just pull the carpet off each side and check if that could be your problem.
Good Luck!
Old Sep 5, 2004 | 10:19 AM
HYBRIDHATCH92's Avatar
Default Re: ek water in trunk (h22ejcoupe)
changed my tail light gaskets and it fixed my problem....try that there cheap
Old Sep 5, 2004 | 11:11 AM
Another Drew's Avatar
If you have a sunroof, make sure the drain tubes are not plugged up from gunk. That's one of the main sources of water leak in cars with a sunroof.
Old Sep 6, 2004 | 01:53 PM
Mr. Vapor's Avatar
Default Re: (Another Drew)
where do they drain too.....the trunk? any more info as to where to look for the drain tubes?
Old Sep 6, 2004 | 01:56 PM
LankorDie's Avatar
Loved
Community Favorite
I have the same problem in my CRX. I think it is my tale light gasket. Where can I get some new ones?
I can post picutures if anyone needs some.
Old Sep 6, 2004 | 02:18 PM
HBP.EH2's Avatar
i have the leaky problem for my eh2
i took part all the rear interior panels and the water was creeping in from the roof....and dripping from where the seat belts are
try and remove the roof molding and there should be clips underneath. spray some 'stop leak' on those clips and the leaking should stop
ek's leak usually because of the rear taillight gasket.....it is recommmeded to use 2 for each light
Old Sep 6, 2004 | 02:44 PM
aznxmike's Avatar
wow, i guess im not the only one with that problem, havent been able to take my trunk apart but i see that some water is coming from the left taillight area, where can i get the gaskets at?
Old Sep 6, 2004 | 04:03 PM
h22ejcoupe
Guest
Posts: n/a
Default Re: ek water in trunk (aznxmike)
obviously try honda
Old Sep 6, 2004 | 04:06 PM
Naturally Aspirated's Avatar
it's motsly caused by the tail light gasket, or the rubbergasket between ur rear glass and the front of ur trunk
Old Sep 6, 2004 | 04:11 PM
The HamsterBall's Avatar
Default Re: ek water in trunk (Naturally Aspirated)
****.. that sucks guys..
what if it's rusted now!!
Old Sep 7, 2004 | 02:31 AM
kidkombo's Avatar
Default Re: ek water in trunk (The HamsterBall)
check your tail light gaskets...usually the factory machine overtightens the taillights causing it to get pinched, hence the water being able to enter the trunk area....in ek hatches this is a common problem and we get that kind of stuff all the time at the honda i work at....
