clutch replacement..
Old Sep 4, 2004 | 04:03 AM
mienhguy's Avatar
Default clutch replacement..
so how do you take the transmission apart?? i did everything the manuals says to do, but i cant take it apart. HELP!!
Old Sep 4, 2004 | 04:10 AM
Calvinator's Avatar
If all of the bolts are taken out and everything thatt he manual said..you should be able to wiggle it out. Some trannys are harder to take out than others. What I did was lean over the passenger fender and grab the tranny on both sides with a firm grip. Then wiggle and pull and it should break loose.
Old Sep 4, 2004 | 05:24 AM
EE_Chris's Avatar
Default Re: clutch replacement.. (mienhguy)
If you're replacing just the clutch, then you don't need to take the transmission 'apart' - you just need to remove it from the car.
If you have all the bolts, brackets, braces, and starter removed, it should come off - try using a screwdriver/hammer to pry it out/knock it out.
One of the dowel pins was straight frozen in the tranny half (when I did this procedure), but this didn't prevent me from pulling my tranny off.
Old Sep 6, 2004 | 09:28 PM
mienhguy's Avatar
thanks for the advice and i got it to work.. **** the whole thing took me about 8 hours.... so releived now
Old Sep 6, 2004 | 09:32 PM
hatchling37's Avatar
Now take it out and drop the clutch at redline to break that ish in! haha
Old Sep 7, 2004 | 04:21 AM
mugenhatch92's Avatar
it is simple you look at all the bolts around the tranny that go to the block, and you take all of those out.....
i bet your problem is that you didnt take out your starter bolts....
gets people everytime
Circaskaterr
Jan 30, 2010 08:46 AM
TigerLy
Jul 1, 2008 07:54 AM
dcturbols
Honda S2000
May 6, 2007 06:18 PM
getdrugtoday
Jan 31, 2005 08:31 AM
Myh4tch
Nov 17, 2003 05:21 AM
