going from chipped p28 to stock p28
I opened up my ECU and it has 2 sockets + chips.
If I wanted to go back to stock would I just remove the chips?
I want to unchip it because I'm using it on my SOHC vtec mini-me and it was chipped for use with a B16 plus VTEC kicks at 4,600 and makes my engine bog a bit I believe stock is higher at 5k+
no you need to get a different chip. I believe it's either $15 or $30 from one from websites. if you just remove the chip your ECU won't have a map to run of. when replacing the chip, remember that they are directional so make sure you put it in the right way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mengy007 »</TD></TR><TR><TD CLASS="quote">hmm Is there a jumper i can remove to bypass the chip and use the stock map/settings?</TD></TR></TABLE>
no, because your stock chip is removed, there is a differenent one on the on the socket, so you can change them out.
madcrx69
Engine Management and Tuning
Jul 21, 2009 08:42 AM
apoptosis
Jan 18, 2008 06:09 PM
