Thinner headgasket or Flat bottom Valves??
Old Sep 3, 2004 | 08:15 PM
NSTY Z33's Avatar
Default Thinner headgasket or Flat bottom Valves??
I have a question. My setup is currently at around 11.3:1 compression(PR3 pistons/GSR). I want to raise compression 4 points at the most. I heard flat bottom valves are not worth just to raise compression, and Mugen/spoon/OEM 2 layer gaskets bring problems. Milling is already out of the question. What can i do??
Old Sep 3, 2004 | 08:48 PM
OLM-02R's Avatar
yeah just get thinner head gasket...to make that .4 points ur looking for...
Old Sep 3, 2004 | 09:31 PM
sohcfreak's Avatar
Default Re: (OLM-02R)
Old Sep 5, 2004 | 12:05 PM
NSTY Z33's Avatar
Default Re: (sohcfreak)
And what exactly can i do to fix timing problems?? Will S2 cam gears do the job??
Old Sep 5, 2004 | 12:29 PM
JL's Avatar
JL
Default Re: (JDMCRXDelSol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRXDelSol &raquo;</TD></TR><TR><TD CLASS="quote">And what exactly can i do to fix timing problems?? Will S2 cam gears do the job??</TD></TR></TABLE>
timing problems?? are you running stock cam gears now? you should make sure everything is top dead center and then do the timing.. cam gears wouldn't be a "maintenance" modification to fix a problem.. they are to make more power above on a normal running healthy motor. have that checked out
Old Sep 5, 2004 | 12:43 PM
Runnerdown's Avatar
Default Re: (JL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JL &raquo;</TD></TR><TR><TD CLASS="quote">
timing problems?? are you running stock cam gears now? you should make sure everything is top dead center and then do the timing.. cam gears wouldn't be a "maintenance" modification to fix a problem.. they are to make more power above on a normal running healthy motor. have that checked out </TD></TR></TABLE>
He means because the head will sit lower and retard the cam timing. Any gears will correct that. I would get the valves if I were you. Omni and rockets valves flow better too.
Old Sep 5, 2004 | 12:57 PM
JL's Avatar
JL
Default Re: (Runnerdown)
sorry.. you are right. yeah get skunk2.
Old Sep 5, 2004 | 06:19 PM
NSTY Z33's Avatar
Default Re: (JL)
It's no problem.
So we got two diff. opinions, hmmmmm.
More opinions please!!
Old Sep 5, 2004 | 08:46 PM
TECH43 RACING INC.'s Avatar
same crap, gasket is cheaper and easier.
however, if you want to get technical, reducing the piston to head and piston to valve clearance (by milling) would be better for horsepower.
Old Sep 5, 2004 | 08:52 PM
Eddiebx's Avatar
y not do both and get even more compression,
Old Sep 5, 2004 | 10:46 PM
SPEEDCORE's Avatar
Default Re: (Eddiebx)
What are people's thoughts on going flat bottom valves, thin H/G so as not to have to skim head so much to acheive desired CR?
Ie. B16A2 = 10.2 CR with flat valves and thin HG could roughly get that to around what..... 10.8? Then would not have to skim head so much to get to say 11.0 CR.
Obviously even though you are not skimming the head so much you are still bringing the valves closer to the piston with the H/G so adj. cam gears are going to be a neccesity to get those cams repositioned.
Old Sep 6, 2004 | 02:24 AM
OLM-02R's Avatar
yeah just do both...
B20EF
Dec 25, 2007 02:47 PM
flatty
May 5, 2006 08:48 PM
crxgsr91
Oct 22, 2004 05:41 AM
tianporn
Aug 10, 2004 03:27 AM
