changing axle seal
Old Sep 3, 2004 | 07:45 PM
huyvu90's Avatar
Default changing axle seal
Is it hard to remove the axle seal from the tranny? How would you position a pry bar to remove it?
Old Sep 4, 2004 | 09:25 AM
ASSASSIN's Avatar
Default Re: changing axle seal (huyvu90)
No, its not hard.
Once you pop the axle out all you have to do is pry it out a little with a screw driver then you can pull it the rest of the way out with your fingers.
Be sure to not scratch the seal surface with the screwdriver or the new seal may not seat good enough.
project91crxsi
Aug 21, 2009 05:56 PM
WPeters
Apr 30, 2008 07:19 AM
8atman
Apr 24, 2006 04:12 PM
B2FiNiTY
Nov 14, 2004 11:08 AM
See Are X
Oct 21, 2003 09:23 PM
