Help Getting Codes 22 and 17 Please help.
Old Sep 3, 2004 | 01:02 PM
BobGnarly's Avatar
Default Help Getting Codes 22 and 17 Please help.
Im am getting codes 22 and 17 and I dont know how to fix it.
22 VTEC pressure valve
17 VSS - speed sensor
wtf...
I have a 99 integra GSR turboed with a Hondata ecu chip in my stock gsr ecu.
any help i would be thankful for.
Old Sep 3, 2004 | 02:12 PM
peacexisxfree's Avatar
Default Re: Help Getting Codes 22 and 17 Please help. (Ultraroms)
my car is also throwing a code 17. i take it your speedo doesnt work? your vss is located near your tranny, but have no idea how difficult it is to re-install. i know i wasnt much help, but me more specific and ill try to be. whats going on with the car since its been throwing these codes?
Old Sep 3, 2004 | 02:15 PM
Default Re: Help Getting Codes 22 and 17 Please help. (peacexisxfree)
i know someone who was quoted 275 for a vss from acura, so id try to go to a junk yard or go through someone you know. and yeah, its located in the back of the trans
Old Sep 4, 2004 | 07:45 PM
SPOON_FED_DC_2's Avatar
The speed sensor takes about 1 or 2 mins to replace its one 10mm bolt then u pull the speed sensor from the tranny. The best thing to do it take ur speed sensor out take the 2 10mm bolts from the sensor plug and look to see if there is a little pin in between the bottom and the top. Also check to see if you speed sensor is turning. Place it in the tranny with the top off and roll the kar forward and if u see it turning it could be the wiring.
Old Sep 5, 2004 | 09:18 AM
BobGnarly's Avatar
Default Re: Help Getting Codes 22 and 17 Please help. (SPOON_FED_DC_2)
my speedo is working perfectly tho
Old Sep 5, 2004 | 09:35 AM
G-bonic's Avatar
Hijacked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ultraroms &raquo;</TD></TR><TR><TD CLASS="quote">my speedo is working perfectly tho</TD></TR></TABLE>
well if u think ur speedo works well try to take off ur battery and count 20 seconds then put it back on and see wut happen... coz it cant be throwin codes if there no reason for it.. try to reset it like i said by takin of ur battery and see wut happen after that...
Old Sep 5, 2004 | 06:17 PM
BobGnarly's Avatar
Default Re: Help Getting Codes 22 and 17 Please help. (Stock_LS)
well my cars impunded right now but i will try that. anyways the check light only comes on when i start my car then goes off or sometimes it jsut comes on randomly.
TEAM JDM-P
Sep 5, 2006 06:48 AM
MUGEN-CRX
May 24, 2005 07:43 PM
SPOON_FED_DC_2
Jul 29, 2004 01:13 AM
Aeka GSR
Jan 20, 2003 03:31 PM
