idle problems with my b16
Old Sep 3, 2004 | 12:42 PM
EFin' Kyle's Avatar
Default idle problems with my b16
ok so i jus swapped a b16 in my crx it starts fine but when it idles it idles atabout 1200rpm tehn drops to 700rpm thn back and forth. whats up with it. i was thinking the idle speed valve. or whatever it is. is that it or no?
Old Sep 3, 2004 | 02:29 PM
j_max420's Avatar
Default Re: idle problems with my b16 (crxstreetracer90)
try taking the idle air control valve(iac) off and cleaning it
Old Sep 3, 2004 | 03:00 PM
FlatlineEF9's Avatar
Default Re: idle problems with my b16 (j_max420)
first try cleaning out the IAC. then if that dont work, take apart your FITV and screw in the white plastic screw. do a search for fast idle thermo valve. i had the same problem last week. sure enough it was the FITV.
Old Sep 3, 2004 | 04:07 PM
b16crx0062004's Avatar
Default Re: idle problems with my b16 (FlatlineLemon)
where is the fitv located?
Old Sep 3, 2004 | 09:32 PM
EFin' Kyle's Avatar
Default Re: idle problems with my b16 (b16crx0062004)
i fixed it thanx guys. i had a loose wire goin to the ecu. thanx
jdmstyleg
Oct 15, 2009 06:55 PM
BrokenRex
Oct 13, 2005 08:25 PM
ej2rider
Jul 9, 2005 06:14 PM
Josh717
Jan 11, 2003 07:08 PM
