Honda S2000 Honda S2000
2000 S2000 Bridgestone S03 Pole
Old Sep 3, 2004 | 10:50 AM
Formula 1's Avatar
Default 2000 S2000 Bridgestone S03 Pole
I just bought a 2000 s2000 a couple weeks ago and I was wondering a couple things
205/50/16 in front about 80% tread
225/50/16 in rear about 20% tread
i was wondering anybody how has this kind of setup do you normal rotate tires in my position or buy new rears? I want to know if there is going to be any vibration in the front?
Also are the wheels in the rear the same width as the front?
Old Sep 3, 2004 | 11:10 AM
Mr. Bagel's Avatar
Default Re: 2000 S2000 Bridgestone S03 Pole (SikCivic)
The wheel sizes are different: 7.5's in the rear and 6.5's in the front. You cannot rotate them, well, you can, but the wheels will not properly fit on the hubs. But to set you up correctly, you need to buy two new tires. They need to be the proper size too: 245/45/16's for the rear, NOT 225/50/16's. The reason the prior owner put on the wrong tires for the S03's, is because the OEM S02's, which are speced out for Honda, specifically the S2000, are marked 225/50/16's, but they are closer to a 250 size, if such a tire existed.
Hope this clears up your questions.
Old Sep 3, 2004 | 10:05 PM
papa5murf's Avatar
Default Re: 2000 S2000 Bridgestone S03 Pole (Mr. Bagel)
nice explenation mr.bagel
Old Sep 7, 2004 | 12:35 PM
Formula 1's Avatar
Default Re: 2000 S2000 Bridgestone S03 Pole (03s2kblue)
the s02 is discontinued and i was wondering does that mean the honda dealers do not have the stock ones left?
Old Sep 7, 2004 | 12:49 PM
alex_b's Avatar
after you've started modding it, such as suspension work, you can actually switch the rear and fronts from side to side to prevent inner tire wear and prolong the life of the tire. but that's a little further down the road
Old Sep 7, 2004 | 01:14 PM
Mr. Bagel's Avatar
Default Re: 2000 S2000 Bridgestone S03 Pole (alex_b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SikCivic &raquo;</TD></TR><TR><TD CLASS="quote">the s02 is discontinued and i was wondering does that mean the honda dealers do not have the stock ones left?</TD></TR></TABLE>
Yes and no. the S02 POLE POSITION tire was discontinued. It was a horrible horrible tire and had a different compound, different size, different tread and treadwear rating than the Honda OEM S02's. The S02 PP was replaced w/the S03 Pole Position. The OEM S02 is still available, but don't go to your dealer to get them, just call up Jim or Conner over at Tire Rack to get you setup with those or the right size for another tire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alex_b &raquo;</TD></TR><TR><TD CLASS="quote">after you've started modding it, such as suspension work, you can actually switch the rear and fronts from side to side to prevent inner tire wear and prolong the life of the tire. but that's a little further down the road </TD></TR></TABLE>
Yes, but that's also another 40-80 bucks to swap out those tires in labor alone. While that might buy you a bit of time, the tires will be hard as a rock and it will be useless to do so. And while you are modding the suspension work, you should exercise the camber of the car a little more, or else, there was very little need in the first place to mod the suspension.
B18C Turbo
Feb 2, 2011 07:01 PM
EFresh
Oct 17, 2010 12:23 PM
S2Kitt
Jan 1, 2009 03:25 PM
ak-s2000
Jan 29, 2004 08:28 AM
YTYPER
Honda S2000
Aug 20, 2002 12:05 PM
