My car won't start, ground problem. please help.
Old Sep 3, 2004 | 10:18 AM
Fuzion's Avatar
Default My car won't start, ground problem. please help.
ok i know your going to tell me to search and i did. i have these grounds on the car now: neg. post to chassis to tranny, valve cover to frame. I know there is supposed to be a ground to the starter but i looked and i can't find one. where is the starter ground supposed to bolt to and coming from where??? please help i need to get to work in the next hour, i'm already late.
TIA
Old Sep 3, 2004 | 10:21 AM
BlueShadow's Avatar
Default Re: My car won't start, ground problem. please help. (Fuzion)
I believe that if you look at your starter you will see somewhere for a spade connector to plug into. The other end of that wire has a ring terminal that goes to the passenger side fuse box (in the engine bay) and connects to one of the two grounding locations. The ring terminal on the engine harness hooks up to the other grounding point in the fuse box.
Old Sep 3, 2004 | 11:27 AM
crx_88_si's Avatar
how about a thermostat ground?
Old Sep 3, 2004 | 11:37 AM
USDM 4G VTEC's Avatar
the starter takes ground off the tranny itself
out from the case
the thermostat housing ground will not allow the engine to run if its not conected
Old Sep 3, 2004 | 12:08 PM
Fuzion's Avatar
Default Re: (USDM 4G VTEC)
the thermostat ground is on. i don't know what the problem is. every ground is on and its still not firing, got fuel just no spark.
Deano_d
Nov 1, 2010 12:37 PM
immrtaltchnq
Sep 22, 2008 05:36 PM
oneslowstd
Nov 23, 2006 01:16 PM
2poor2tune
11
Oct 11, 2006 02:39 PM
SpoolinEK
10
Oct 27, 2003 04:27 AM
