fully built all motor sleeved b18c5 for sale
Testing waters.
Ok so ill list it from the cover down
type r valve cover
peak intake manifold
gsr throttlebody
str fuel rail with stock injectors
sx fuel pressure regulator
type r cams
peak cam gears
rev springs and retainers
new valveseals and entire seal kit for head
95 gsr head
arp headstuds
new obd1 distributor
commetic 86mm headgasket
darton open deck sleeved b18c5 01 block (sleved by rs machine in 03)
endyn rollerwave 12.0:1 strutted gas ported 86mm pistons
crower pro rods
new type r crank
acl bearings
pro drive oil pump gears and newer r oil pump
moroso oil pan and pickup
kaiten flywheel
act xx pressure plate
rps 6 puck sprung disc
95 gsr transmission, no grinds,
stock gsr exhaust manifold
The rest of the parts are all from a 01 itr, example intermediate shaft, linkage and shifter(with urethane bushings), gsr axles and chipped p28 are only items not from r.
this is a complete swap, and its not even been turned over since i bored it from 85 to 86mm and had my my 9.0 pistons replaced with these 12.0's. The motor is in excelent condition and with some differant cams, bigger injectors, and a nice header in a light chassis, i could see it turning some SERIOUS low times.
asking 6500.00
Trades concidered.
pm for details.
Modified by colt45.5 at 11:27 AM 9/3/2004
type r valve cover
gsr throttlebody
type r cams
peak cam gears
95 gsr head
arp headstuds
crower pro rods
new type r crank
acl bearings
kaiten flywheel
asking 6500.00
Trades concidered.
pm for details.
