Flex-a-lite twinline fan, model 320 for sale
I never post here since I am a VW guy, but I have this fan that I can't use on my setup so it is for sale. You can go over to http://www.vwvortex.com and look me up under the name vfarren if you are afraid I'll rip you off. I have been on there a long time and have had successful deals with erveryone there. Now, on to the fan:
I have a slightly used Flex-a-lite twinline fan, model 320 for sale. I bought it slightly used and never installed it. It is a little too big for my Rabbit and decided to go with another smaller FAL fan so this one is up for sale. It is in great shape. This fan retails for $185 at Summit racing and Jegs.
I am asking for $100 + shipping.
contact me at farrenator@yahoo.com
http://www.flex-a-lite.com/aut....html
Twin Line Fans
Part # 320 - Puller or Pusher
Designed to replace the stock horsepower robbing factory fan, where applicable. Shrouded dual 10" fan configuration allows for maximum airflow yet requires very little mounting space. Used as a primary cooling fan, the Twinline can extend water pump life, increase horsepower and gas mileage.
Features:
• One piece, lightweight plastic shroud with full contact rubber seal maximizes cooling area
Part # - 320 Reversible
Mounting Surf. Req'd - 22" x 11 1/4" x 4 1/8"
Fan Diameter - 2 x 10"
Fan RPM @13.5VDC - 2500
Number of Blades/Fan Blade Angle - 10/20°-40°
Airflow-Cu. Ft./Min. at 0º Static Pressure - 1800
Amp Draw - 15
Mounting System - Thru Core
Adj. Thermostat 180º-240º - No
Air Conditioning Relay - No
Twin Line Fans
Features:
Amp Draw - 15
