FS: 5.6" LCD Display with FM Modulator
Old Dec 6, 2001 | 05:22 AM
tvrvic's Avatar
Default FS: 5.6" LCD Display with FM Modulator
I have for sale a 5.6" LCD and FM Modulator that I had in my car 3 days. I will let the package go for $215 shipped. The FM Modulator has 6 selectable channels and plugs in between your antenna and head unit. I used it in my car with a playstation2. So once again ::
$215 Shipped. Gets you this :
and the FM modulator! email if you have any questions. vic@purehonda.com Thanks!
High resolution display
Fully Compatible With Any Standard Composite (RCA) Video Signal (i.e works with all of the following... VCRs, ANY Video Game System, GPS, Navigation Systems, VCR and even Video Cameras)
Small Size Allows You To Mount This Almost ANYWHERE (possible choices would be either the back of a headrest or even in your own custom enclosure) THE CHOICE IS YOURS
You Can Even Separate The Actual Screen Itself From the Board That It Is Mounted To Allowing An Even Thinner Install
Long-Life Cold Calthode Fluorescent Lamp
Thin-film Transistor technology "TFT"
Screen even has "reverse image switch" which would allow you to use this with a rearview camera and use as a rearview mirror
Specifications
12 VDC Drawing ONLY 750mA
Resolution: 960 x 234= 224,640 pixels
Controls for Color, Brightness, And Tint
Viewing area (mm):115.2 W x 84.2 H
Overall dimensions (mm): 140 W x 105 H x 32 D
paypal only please... thanks
[Modified by tvrvic, 6:23 AM 12/6/2001]
Old Dec 6, 2001 | 11:06 AM
tvrvic's Avatar
Default Re: FS: 5.6" LCD Display with FM Modulator (tvrvic)
aww cmon... you can hook it up to your laptops video out and watch your hondata logging...
ttt!
Old Dec 6, 2001 | 01:21 PM
KJEG94's Avatar
New User
will this hook up to a dvd deck
Old Dec 6, 2001 | 03:30 PM
tvrvic's Avatar
Default Re: FS: 5.6" LCD Display with FM Modulator (KJEG94)
Depends on the output from the DVD Deck. If the dvd deck has RCA Video out then yeah it would work no problem...
Old Dec 6, 2001 | 03:54 PM
tvrvic's Avatar
200 Shipped Now....
Old Dec 6, 2001 | 04:02 PM
fsarfino's Avatar
you said this will hook up to a laptop did you mean as a secondary display??
Old Dec 6, 2001 | 04:04 PM
tvrvic's Avatar
Default Re: FS: 5.6" LCD Display with FM Modulator (dohcvtec16)
If the laptop has RCA video out which some do. I know some dells came with a cable that provided RCA and SVIDEO out and some toshibas had an actual RCA jack. It would most likely become the only display (depends on the laptop) so I was going to hide the laptop under the seat and just mount this under my radio so I could watch what was going on.
[Modified by tvrvic, 5:05 PM 12/6/2001]
efb16
May 26, 2006 05:20 PM
chap99cvc
Jan 13, 2003 10:06 AM
