Is it ok to grind off the valve guide to make it flush with the port?
Old Sep 3, 2004 | 03:22 AM
eightvalver's Avatar
Default Is it ok to grind off the valve guide to make it flush with the port?
Is it ok to grind off the valve guide to make it flush with the port? or will it make the valve train unstable at higher RPM?
Old Sep 3, 2004 | 04:19 AM
Big Teggie's Avatar
Default Re: Is it ok to grind off the valve guide to make it flush with the port? (eightvalver)
Is this a full race head or for a street car?
Old Sep 3, 2004 | 05:03 AM
1 2 NV's Avatar
Default Re: Is it ok to grind off the valve guide to make it flush with the port? (Big Teggie)
personally i wouldnt flush it for street or strip.
Old Sep 3, 2004 | 08:19 AM
JDMotive's Avatar
You CAN do it,but there's really no reason to.It doesnt increase flow that much.Ive done it on a few of my heads in the past and really and no adverse effects.Those engines revved to 9k+ rpm all of the time and had no problem.People used to do it all of the time because they were lazy and didnt want to spend the extra time porting around them.
Old Sep 3, 2004 | 09:38 AM
Rick Solis's Avatar
Default Re: Is it ok to grind off the valve guide to make it flush with the port? (JDMotive)
Ive known many that have run heads with flush guides on both street and strip aplication with no problems at all...
Ive seen anywhere from a 5-10 CFM increase when done properly...
Teamdiesel
104
Dec 31, 2008 10:27 AM
Suzukii
Dec 23, 2005 10:35 AM
bukbukintegra
Nov 16, 2005 01:14 AM
VSBB6
Sep 11, 2005 11:07 AM
