Best Piston Compression for All Motor
I have been told that with an All Motor setup that a 11:1 or 11:3 compression is the best.....Wondering what the best to use for daily driver and 91 octane........
Modified by 24K SI at 5:09 AM 9/3/2004
All this talk of compression and not once a mention of cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES »</TD></TR><TR><TD CLASS="quote">As high as you can safely tune. It also depends on how often it's driven on the street, if at all.</TD></TR></TABLE>
Again, I disagree. If your compression is too high, the piston starts to lose velocity as it reaches TDC, and your high end power suffers.
Wild cam engines can get away with running insane compression because so much is bled during the compression stroke, because the intake valves are still slightly open due to overlap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG »</TD></TR><TR><TD CLASS="quote">All this talk of compression and not once a mention of cams.
True. I kinda thought about that after what I typed, but I guess if you consider runing a cam with lots of duration, that bleeds a lot of compression, then you can get away with running a higher amount. 91 octane is quite a limiting factor.
Rhymenoceros
15
Apr 15, 2006 03:59 PM
1.8T_EG
Apr 27, 2003 12:16 PM
