weird vibration after header install
Old Sep 3, 2004 | 12:38 AM
es_squared's Avatar
Default weird vibration after header install
not sure if rattle is the right word for it, but i can feel it in the pedals more than hear it really. feels liek its coming from the left side of the car (even tho the header is in the center), but only happens at lower rpms when i give it extra gas.
could it be from running a bit rich ?
Old Sep 3, 2004 | 12:42 AM
andeh22's Avatar
Default Re: weird vibration after header install (es_squared)
i posted a topic just like this.
people said it was a leak, or need new gaskets.
i got both of those fixed.. BUT i still have that rattling noise also. but past like.. 3500-4000 rpm its fine. just rpms under that.
so..im still wondering the same question.
Old Sep 3, 2004 | 08:45 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: weird vibration after header install (andeh22)
What kind of header?
It could be the cat conv. or heat shield.
I had the same problem on my lude. Fortunately, the rattle/buzz went away.
Old Sep 3, 2004 | 08:46 AM
SKDRCR's Avatar
Default Re: weird vibration after header install (Sticky Tires)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sticky Tires &raquo;</TD></TR><TR><TD CLASS="quote">What kind of header?
I had the same problem on my lude. Fortunately, the rattle/buzz went away. </TD></TR></TABLE>
yep, check your heatshields, they could be rubbing your exhaust
somewhere
Old Sep 3, 2004 | 09:09 AM
98TypeSH's Avatar
Default Re: weird vibration after header install (SKDRCR)
didnt you say you rear-ened someone and the header was now hitting the cross member? well that would cause a nice little rattle. At low RPM's the exhuast shakes more due to the flow of the air. Its not moving as fast thus causing turbulence. Little bit higher rpms, exhuast doesnt shake as much, hence no rattle. Can you tell where the rattle is comming from? feel it in your pedal? under the seat? so on a so forth.
Old Sep 3, 2004 | 09:46 AM
es_squared's Avatar
Default Re: weird vibration after header install (98TypeSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">didnt you say you rear-ened someone and the header was now hitting the cross member? well that would cause a nice little rattle. At low RPM's the exhuast shakes more due to the flow of the air. Its not moving as fast thus causing turbulence. Little bit higher rpms, exhuast doesnt shake as much, hence no rattle. Can you tell where the rattle is comming from? feel it in your pedal? under the seat? so on a so forth.</TD></TR></TABLE>
its a prospeed header. but this was happeneing before i rearended the guy, and i looked closer the other day and the header has like an inch clearance off the crossmember so i doubt its rubbing against that.. could it be my cats gone bad?
Old Sep 3, 2004 | 09:58 AM
* B A N N E D *
Yes most likely your cat's gone bad. Do you have an intake?
Old Sep 3, 2004 | 10:03 AM
es_squared's Avatar
ya , aem cold air
Old Sep 3, 2004 | 10:06 AM
k_dog's Avatar
It may be the Cat then. Or it could also be anything loose in the exhaust system. Try leaving the car on, and looking underneath the chassis while someone else revs the motor at low RPM's. Maybe then you can hear/see the rattle because you said the rattle was at low-mid RPM level.
-Brian
Old Sep 3, 2004 | 10:14 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by es_squared &raquo;</TD></TR><TR><TD CLASS="quote">ya , aem cold air</TD></TR></TABLE>
Make sure your K&N intake isn't rubbing against metal. I've heard stories of it causing rattle/buzzing sounds.
Old Sep 3, 2004 | 10:34 AM
es_squared's Avatar
thanks guys ill give those ideas a shoty
Old Sep 3, 2004 | 10:48 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by es_squared &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys ill give those ideas a shoty</TD></TR></TABLE>
LudeJdm
19
Nov 8, 2005 09:17 AM
sniffthese
Apr 30, 2005 08:49 PM
NinjaTech
Mar 9, 2005 05:14 PM
hoehouseworker
Sep 29, 2004 08:31 PM
fivespeedintegra
Jun 3, 2003 11:59 AM
