where to look for info for 90 accord ex A/C system??
Whats the story? Can you jumper the pressure switch and make the compressor and fans run? Here's another good link.
http://www.ackits.com/forum/
i am new to everything for the most part.
the fans do come on.
the a/c turns on just not cold. i am guessing the compressor is hashed. i am nto sure if there are leaks though and what not.
i want to convert it to r134 and charge it back up and go from there and diagnose things.
bump for ideas and help in diagnosing.
so if i take it to a shop and they charge it w/ r12 (which it says). what can it do? will they tell me what is exactly wrong? if there is a leak, which major component is exactly hashed??
i was thinking of changing all the components..
thanks
thanks
Go back and look at the thread the last time you asked about this a month ago. My advice then was buy a manual and read it. None of this happens by osmosis. TxTuner said it even better...RTFM!!!
hondalite
Oct 28, 2005 08:41 AM
(That is: READ THE ******* MANUAL!!!!)
