wiring regard h22 swap into a 88 lude
Old Sep 2, 2004 | 04:32 PM
kedge's Avatar
Default wiring regard h22 swap into a 88 lude
have managed to separate the computer harness from the factory wiring from the 92 prelude and have pluged this into the engine and run though the firewall to ware the computer goes
have managed to find the 3 wires on the car hot at all times,hot in start,hot in on or start.
now on the computer for the h22a wiring diagram (hot in or on start) conects to a blk/yel wire but this conects to the control valves and then goes the computer
what i need to know is if i conect the (hot in on or start) to the computer wires will the control valves work or do i need to power the blk/yel wire, if so were would i find this
were do i find the ecm main relay is it inside the computer or is a separate computer someware else
i have gone and chooped out the computer service cheak connector does this need to be installed for the car to start.
any help would be greatly appreated
thanks
kevin
Old Sep 2, 2004 | 11:08 PM
Not_Rice4ws's Avatar
you are on the rigth track!
what my recommendation would be is this:
go to preludepower.com and PM afterburners.
he has done this re wire and has alot of knowledge about it. not only that for a small fee he will wire your harness for you!
-good luck
jniner
Nov 6, 2006 07:03 AM
icucnme
Oct 5, 2005 07:27 PM
efjuice
19
Sep 8, 2003 05:16 PM
