big cam question please help!!!!
i just installed s2s2 cams,retainers,springs, and gears. right before i hit vtec its like my car hits a wall and then the vtec kits in. i have the dc sorts 4-1 header with a 2.25 collector or could it be the lack of a hight flow cat, please help
hopefully you didn't put those cams in a stock motor. They are made for higher compression. If you have sufficient compression than most likely you just need some fuel tuning and u need to change your vtec crossover.
i am going to go to a obd1 computer that is chipped for the cams, and i just ordered a header with a 2.5'' collector and a test pipe, i also need to get my compression up to around 12.5.1 and then hopefully i will be good to go, thanks for all your guys help
blowme
Jun 24, 2005 06:37 AM
