A/C problems i could use alot of help
Old Sep 2, 2004 | 03:40 PM
knightnam's Avatar
Default A/C problems i could use alot of help
ok, this is what is wrong with the car. i bought it like this so i don't know where to start.
from the looks of things seems like the a/c would work but it doesn't. im not sure if it needs to be recharged or not but. when i turn on the a/c the car acts as if i never turned it on. usually it drops idle or something. well at least that is what happened in my old car. im asking for advice from these pictures because i am on a mechanic so i don't know much about a/c units.
if you guys could post a few words of advice that would be great.
Old Sep 2, 2004 | 03:58 PM
G-bonic's Avatar
Hijacked
Default Re: A/C problems i could use alot of help (knightnam)
why needing AC in chicago illinois ?? u dont need it i dont have none of my AC components and im from cali hot as hell in summer... get over it take everything off tell ur mechanic fukk it take all the AC components...
Old Sep 2, 2004 | 04:19 PM
knightnam's Avatar
Default Re: A/C problems i could use alot of help (Stock_LS)
sorry i can't do that. i like a fast car and all. but when you always are on the road i need the car also to be comfortable and relaxing. what im looking for is answers or ideas on what is wrong. thanx for the advice tho. my bro told me the same thing.
Old Sep 2, 2004 | 04:30 PM
chero112's Avatar
get like a pen or something sharp and press it were you refuel the ac at and see if anything comes out or not. Might need to be refueled, if not might be the compressor. does the fan go on when you press the AC button.
Old Sep 2, 2004 | 04:36 PM
knightnam's Avatar
Default Re: A/C problems i could use alot of help (chero112)
i don't think there is a fan. because when i push the button nothing turns on. i don't see an a/c fan in the pic.
Old Sep 2, 2004 | 05:34 PM
Droppedatbirth!'s Avatar
theres a fan on the radiator side just not on a/c side if it doesint drop idle first off check your relay for your ac get the compressor to turn on first then go from there
Old Sep 2, 2004 | 05:45 PM
GreensleeperB16's Avatar
You seem to be missing condersor and fan assembly... might be a clue...
Old Sep 2, 2004 | 06:02 PM
Arsenal's Avatar
Default Re: (GreensleeperB16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreensleeperB16 &raquo;</TD></TR><TR><TD CLASS="quote">You seem to be missing condersor and fan assembly... might be a clue... </TD></TR></TABLE>
Old Sep 2, 2004 | 06:46 PM
El_Jefe's Avatar
lol, also i don't think having your a/c line sitting on your down pipe is a good thing
Old Sep 2, 2004 | 07:15 PM
mickey513's Avatar
Like what someone pointed out:
There's no AC fan or condensor.....
Whhooppss NO AC FOR YOU.
Old Sep 2, 2004 | 07:24 PM
knightnam's Avatar
Default Re: A/C problems i could use alot of help (mickey513)
i have my fan and condensor from my old ej1 is that interchangeable with the integra's?
Old Sep 2, 2004 | 08:06 PM
WhiteGSR95's Avatar
from what ive seen most d series and b series seem to have the same ****, dont quote me on that though
Old Sep 2, 2004 | 09:31 PM
jdm91integ's Avatar
When you push the button to turn your AC on does the compressor spin at all? What about both of the AC lines that are going to the compressor, they're both touching your dump tube. Aren't you worried about them melting?
whitx2
Aug 3, 2016 10:24 PM
Katastrophic
15
Jun 29, 2011 10:33 PM
Lauj87
Jul 4, 2006 01:02 PM
crazyteg95
Oct 8, 2004 10:37 AM
sk8phaze
May 14, 2003 04:04 PM
