swap info needed please !! crx si- ls
Old Sep 2, 2004 | 01:11 PM
legacytunes's Avatar
Default swap info needed please !! crx si- ls
i have a 1989 crx si and i wanna now if i should go with a b18a or a b18b i now that the crx si is obd-0 and the b18-b is obd-1 ............ but the qustion is wich one is easyest. If i have to, how do i wire up the ls obd-0 distibuter? i might this rout cause its cheaper. please if you can i need detailed information
Old Sep 2, 2004 | 01:13 PM
SIRX's Avatar
Default Re: swap info needed please !! crx si- ls (legacytunes)
not to burst your bubble but do a search. This has been covered alot. You can find out everything you need with the search function
Old Sep 2, 2004 | 01:22 PM
EL Vap133's Avatar
Easiest? OBD0 is the easiest.
Old Sep 2, 2004 | 01:23 PM
LAMA's Avatar
Default Re: swap info needed please !! crx si- ls (EL Vap133)
whats the poll for?
i voted civic
Old Sep 2, 2004 | 01:25 PM
Default Re: swap info needed please !! crx si- ls (SIRX)
ok thankx
Old Sep 2, 2004 | 02:04 PM
92integra_gs's Avatar
staying obd-0 w/ b18a1 (its cheaper than the b18b) its basically the same thing... w/ the exception of the cams and intake manifold...
crxjarred
Jul 27, 2008 09:49 AM
CRXRTYPE
Aug 5, 2004 01:02 PM
yellowCRX6
Mar 26, 2004 08:13 AM
